1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsqt question
To: Andrew Rhyder <[email protected]>, EPICS <[email protected]>
Date: Wed, 3 Feb 2016 11:37:23 -0500
Hi Andrew,
I had installed it from source some time ago. I just svn'd the trunk again and tried to build it in Creator. Creator complains about XStretch and YStretch being undeclared in class 'QEImage'. Any suggestions?
Pete.
On 02/02/2016 09:24 PM, Andrew Rhyder wrote:
Hi Pete
Yes there is a way. The bad news is it involves a code change. The good news I just did it.
I've added a couple of properties (XStretch and YStretch) that you can use to stretch (or contract) the canvas used to present an image. So zoom, flip, rotate all do what they used to, but rather than then set the canvas to match the resultant image exactly, these properties will stretch the canvas (and the images drawn to it) as required. In your case you will can stretch the canvas vertically by, say, 10.0.
The latest source on sourceforge has this change. Have you build epicsQt from source, or did you use a prebuilt version?
Regards
Andrew
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of D Peter Siddons
Sent: Wednesday, 3 February 2016 7:05 AM
To: EPICS
Subject: epicsqt question
Is anyone out there working with epicsqt? I am trying to display a set
of 64 spectra (in Y) , each 4096 points (in X), as a QeImage. As you
might expect, it looks long and narrow. I would like to stretch the
pixels in the Y direction to make a more rectangular display. Is there a
way to persuade QeImage to do this?
Pete.
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
RE: epicsqt question Andrew Rhyder
epicsqt question D Peter Siddons
Prev: RE: Show areaDetector image with BOY IntensityGraph Mark Rivers
Next: Re: Show areaDetector image with BOY IntensityGraph Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: epicsqt question Andrew Rhyder
Next: RE: epicsqt question Andrew Rhyder
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
