Hi Philippe,
I looked at the code and I believe I see the error. In fact I think the error occurs in 2 places. One is for I/O Intr scanned records (like you are using) and the other is for periodically scanned records. Can you change your database temporarily so that the waveform record is periodically scanned and see if you get the same problem? If so I will fix the driver and have you test.
From: [email protected] [[email protected]] on behalf of Philippe Laurent [[email protected]]
Sent: Tuesday, February 02, 2016 2:37 AM
To: [email protected]
Subject: Modbus 2.5 How to read a INT32_BE array from a modbus function
Hello,
I try to read a INT32_BE array from a modbus function into a Waveform using dtyp = asynInt32Array.
I get a array of long in the waveform, but the data are not correctly read from modbus.
It looks like, the driver constitutes a long with :
modbus index 0 + modbus index 1-> waveform data[0]
modbus index 1 + modbus index 2-> waveform data[1]
modbus index 2 + modbus index 3-> waveform data[2]
Instead of :
modbus index 3 + modbus index 4-> waveform data[3]
My record is :
record(waveform, $(EQPT):PostMortemRaw2) {
field(DTYP, "asynInt32ArrayIn")
field(DESC, "input modbus data")
field(NELM, "50")
field(FTVL, "LONG")
field(SCAN, "I/O Intr")
field(INP, "@asyn($(EQPT):PostMortemRd2 0)INT32_BE")
My modbus function is :
drvAsynIPPortConfigure("LBEC-DCCT31","172.16.60.231:502",0,0,1)
modbusInterposeConfig("LBEC-DCCT31",0,300,2)
drvModbusAsynConfigure("LBEC-DCCT31:PostMortemRd2","LBEC-DCCT31",1,3,228,100,6,2000,"PLC")
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
- RE:Modbus 2.5 How to read a INT32_BE array from a modbus function Philippe Laurent
- Modbus 2.5 How to read a INT32_BE array from a modbus function Philippe Laurent
<2016>
<2016>
