1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks 6.9
To: Stefen Paul <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 29 Jan 2016 17:17:16 -0600
Hi Stefen,
On 01/27/2016 11:23 PM, Stefen Paul wrote:
> I think I will prefer the first option that involves some tweaking in
> the BSP.
> Because I feel it will be more systematic and persistent.
> So please share the information about the same.
Ok, I will write that up and post it here next week.
> I would also like to draw your attention to my initial query:
> " Is it true that VxWorks 6.9 BSP for MVME-5500 can't make use of VME64
>  addressing capabilities even if the SBC on which it is running has this
> feature ?
> Because in config.h I can see only A16, A24 and A32 address space
> details."
What do you mean by "VME64 addressing capabilities"? If you're talking
about accessing VME A64 space, the Tundra Universe-2 VME interface chip
on the MVME5500 doesn't support accesses to that space at all (you need
a board like the MVME6100 or MVME3100 that uses the Tempe TSI-148 chip
instead for that). If you mean the ability to use VME64x geographical
addressing, isn't that what the CR/CSR space is for?
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
Re: VxWorks 6.9 Andrew Johnson
VxWorks 6.9 Stefen Paul
Re: VxWorks 6.9 Stefen Paul
Prev: Re: set-user-id root and EPICS 3.15 Maren Purves
Next: Re: set-user-id root and EPICS 3.15 Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks 6.9 Bjorklund, Eric A
Next: Re: VxWorks 6.9 Andrew Johnson
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
