1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: set-user-id root and EPICS 3.15
To: "J. Lewis Muir" <[email protected]>, Till Straumann <[email protected]>, [email protected]
Date: Fri, 29 Jan 2016 13:14:23 -1000
On 01/29/16 13:04, J. Lewis Muir wrote:
On 1/29/16 3:54 PM, Till Straumann wrote:
- the code uses these features (RT scheduling + mlockall) *only*
   if you give it sufficient privilege to use them. If it has the
   privileges then the code assumes you want it to use them.
This is perhaps the real issue: the code assumes it should use
something just because it has sufficient privileges to do so.  If I'm
understanding things correctly, if I want to run something as root (or
with certain capabilities) *without* RT, I can't do it.  But a toggle
for RT would allow me to do it.
Agree with Lewis that something like this should not be automatic.
Imagine a user (like e.g. a system administrator) with privileges
runs something that includes this and it all works fine. Then somebody
else  (e.g. a telescope operator) without the same privileges runs it
and it doesn't. To even trouble shoot what exactly the problem is I'd
have to find a non-privileged account and run it ... turning it on and
off via an option would be much easier (and if it needs it we can
always install it with privilege and the option).
Aloha,
Maren
set-user-id root and EPICS 3.15 Gerry Swislow
RE: set-user-id root and EPICS 3.15 Mark Rivers
Re: set-user-id root and EPICS 3.15 Ralph Lange
Re: set-user-id root and EPICS 3.15 Andrew Johnson
Re: set-user-id root and EPICS 3.15 Till Straumann
Re: set-user-id root and EPICS 3.15 J. Lewis Muir
Prev: Re: set-user-id root and EPICS 3.15 J. Lewis Muir
Next: Re: VxWorks 6.9 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: set-user-id root and EPICS 3.15 Till Straumann
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
