1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: set-user-id root and EPICS 3.15
To: "Rivers, Mark L." <[email protected]>, "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 29 Jan 2016 21:43:39 +0000
I agree
  Pete R. Jemian, Ph.D.                <[email protected]>
  Beam line Controls and Data Acquisition, Group Leader
  Advanced Photon Source,   Argonne National Laboratory
  Argonne, IL  60439                   630 - 252 - 3189
     Education is the one thing for which people
        are willing to pay yet not receive.
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Friday, January 29, 2016 3:07 PM
To: Johnson, Andrew N.; [email protected]
I vote for the EPICS_RT_MLOCKALL run-time variable.  I would like to a have a single build of EPICS base.
SPEC is the application that started this thread.  When SPEC is installed it not plre-linked against EPICS base.  Rather one points it to the site-version of EPICS base, which is then links against.   I don't want to have one version of EPICS base with mlockall() disabled for SPEC and another version with it enabled for my IOCs.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Friday, January 29, 2016 2:56 PM
To: [email protected]
Subject: Re: set-user-id root and EPICS 3.15
On 01/28/2016 08:43 AM, Ralph Lange wrote:
> However, this is the second time that we hear of trouble because people
> are running client applications (i.e. CA clients) in real-time context.
> In those cases, the memory locking might not be intended nor useful.
> There is no way for the OS abstraction layer (where the memlock happens)
> to know if the caller is an IOC type or a client type application.
> We already began to reconsider the automatic activation feature.
I think it would be reasonable to require those that want the mlockall()
behaviour to configure it. The main question would be whether this
should be configurable at build-time, or if it can require a run-time
setting. The simplest fix would be something like this:
=== modified file 'src/libCom/osi/os/posix/osdThread.c'
--- src/libCom/osi/os/posix/osdThread.c 2015-03-19 15:22:15 +0000
+++ src/libCom/osi/os/posix/osdThread.c 2016-01-29 20:41:08 +0000
@@ -362,7 +362,8 @@
         fprintf(stderr, "LRT: min priority: %d max priority %d\n",
             pcommonAttr->minPriority, pcommonAttr->maxPriority);
-    if (pcommonAttr->maxPriority > pcommonAttr->minPriority) {
+    if (getenv("EPICS_RT_MLOCKALL") &&
+        pcommonAttr->maxPriority > pcommonAttr->minPriority) {
         status = mlockall(MCL_CURRENT | MCL_FUTURE);
         if(status) {
             fprintf(stderr, "Unable to lock the virtual address space
using mlockall\n");
That would require IOCs that need the memory locking to have set the
EPICS_RT_MLOCKALL environment variable before they are executed. A
slightly more complicated solution would allow locking to be turned on
at build-time in the configure/CONFIG_SITE_ENV file, but it could be
turned off again at run-time with an environment variable.
If you currently rely on the current mlockall() behaviour of Base and
wish to influence our decision, please speak up before we commit any
changes.
- Andrew
There are only two hard problems in distributed systems:
  2. Exactly-once delivery
  1. Guaranteed order of messages
 -- Mathias Verraes
set-user-id root and EPICS 3.15 Gerry Swislow
RE: set-user-id root and EPICS 3.15 Mark Rivers
Re: set-user-id root and EPICS 3.15 Ralph Lange
Re: set-user-id root and EPICS 3.15 Andrew Johnson
Prev: RE: set-user-id root and EPICS 3.15 Mark Rivers
Next: Re: set-user-id root and EPICS 3.15 Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
