1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Pilatus Detector.. IOC NO Response
To: mujin park <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Jan 2016 14:30:23 +0000
You have set AcquirePeriod=0 and AcquireTime=1.  That is not allowed, AcquirePeriod must be at least AcquireTime + readout time, for example 1.004.  Because you have set NumImages=1 this is not a serious problem, the AcquirePeriod is not really used by camserver in this case because it is only collecting a single image.  But it still returns an error message when you set it incorrectly.
From: [email protected] [[email protected]] on behalf of mujin park [[email protected]]
Sent: Monday, January 25, 2016 8:17 AM
To: [email protected]
Subject: Pilatus Detector.. IOC NO Response
Hello..
We use Pilatus Detector...
In first time, it worked...
but  when i restarted...
2016/01/25 18:08:25.791 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period
this message is...
i don't know  What is problem..
the camserver is  alive (it is OK in ping test)
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocPilatus")
epicsEnvSet("TOP","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1")
epicsEnvSet("SUPPORT","/usr/local/epics/R3.14.12/modules/synApps_5_6/support")
epicsEnvSet("ASYN","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/asyn-4-18")
epicsEnvSet("CALC","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/calc-2-9")
epicsEnvSet("BUSY","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/busy-1-4")
epicsEnvSet("SSCAN","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/sscan-2-7")
epicsEnvSet("MCA","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1")
epicsEnvSet("AUTOSAVE","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/autosave-4-8")
epicsEnvSet("AREA_DETECTOR","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1")
epicsEnvSet("EPICS_BASE","/usr/local/epics/R3.14.12/base")
errlogInit(20000)
dbLoadDatabase("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/dbd/pilatusDetectorApp.dbd")
pilatusDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("EPICS_CA_SERVER_PORT", 6064)
epicsEnvSet("EPICS_CA_REPEATER_PORT", 6065)
epicsEnvSet("PREFIX", "BL5C_:")
epicsEnvSet("PORT",   "PIL")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "487")
epicsEnvSet("YSIZE",  "195")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CAMSERVER", "10.0.1.100")
# Create the asyn port to talk to the Pilatus on port 41234.
drvAsynIPPortConfigure("camserver","10.0.1.100:41234<http://10.0.1.100:41234>")
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
asynOctetSetOutputEos("camserver", 0, "\n")
pilatusDetectorConfig("PIL", "camserver", 487, 195, 50, 200000000)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/ADBase.template", "P=BL5C_:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/pilatus.template","P=BL5C_:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "PIL", 0, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStdArrays.template", "P=BL5C_:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=94965")
# Load all other plugins using commonPlugins.cmd
< ../commonPlugins.cmd
# Create a netCDF file saving plugin.
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "PIL", 0)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template",      "P=BL5C_:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileNetCDF.template","P=BL5C_:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "PIL", 0)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template",      "P=BL5C_:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileTIFF.template",  "P=BL5C_:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "PIL", 0)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template",      "P=BL5C_:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileJPEG.template",  "P=BL5C_:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "PIL", 0)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template",      "P=BL5C_:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileNexus.template", "P=BL5C_:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "PIL", 0)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template",      "P=BL5C_:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileHDF5.template",  "P=BL5C_:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1")
# Create a Magick file saving plugin
NDFileMagickConfigure("FileMagick1", 20, 0, "PIL", 0)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template",      "P=BL5C_:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileMagick.template","P=BL5C_:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template",       "P=BL5C_:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI2", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template",       "P=BL5C_:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI3", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template",       "P=BL5C_:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI4", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template",       "P=BL5C_:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDProcess.template",   "P=BL5C_:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI1,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template",     "P=BL5C_:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195")
NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI2,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template",     "P=BL5C_:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195")
NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI3,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template",     "P=BL5C_:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195")
NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI4,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template",     "P=BL5C_:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195")
NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template",     "P=BL5C_:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195")
# Create "fastSweep" drivers for the MCA record to do on-the-fly scanning of Stats data
initFastSweep("SweepTotal1", "STATS1", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD")
initFastSweep("SweepNet1",   "STATS1", 1, 2048, "NET_ARRAY",   "CALLBACK_PERIOD")
initFastSweep("SweepTotal2", "STATS2", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD")
initFastSweep("SweepNet2",   "STATS2", 1, 2048, "NET_ARRAY",   "CALLBACK_PERIOD")
initFastSweep("SweepTotal3", "STATS3", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD")
initFastSweep("SweepNet3",   "STATS3", 1, 2048, "NET_ARRAY",   "CALLBACK_PERIOD")
initFastSweep("SweepTotal4", "STATS4", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD")
initFastSweep("SweepNet4",   "STATS4", 1, 2048, "NET_ARRAY",   "CALLBACK_PERIOD")
initFastSweep("SweepTotal5", "STATS5", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD")
initFastSweep("SweepNet5",   "STATS5", 1, 2048, "NET_ARRAY",   "CALLBACK_PERIOD")
# Load MCA records for the fast sweep drivers
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats1:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal1 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats2:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal2 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats3:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal3 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats4:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal4 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats5:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal5 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats1:NetArray,  DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet1 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats2:NetArray,  DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet2 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats3:NetArray,  DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet3 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats4:NetArray,  DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet4 0)")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats5:NetArray,  DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet5 0)")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDTransform.template", "P=BL5C_:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "PIL", 0, 8, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlay.template",   "P=BL5C_:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=BL5C_:ROI1:MinX_RBV,YPOS=BL5C_:ROI1:MinY_RBV,XSIZE=BL5C_:ROI1:SizeX_RBV,YSIZE=BL5C_:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=BL5C_:ROI2:MinX_RBV,YPOS=BL5C_:ROI2:MinY_RBV,XSIZE=BL5C_:ROI2:SizeX_RBV,YSIZE=BL5C_:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=BL5C_:ROI3:MinX_RBV,YPOS=BL5C_:ROI3:MinY_RBV,XSIZE=BL5C_:ROI3:SizeX_RBV,YSIZE=BL5C_:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=BL5C_:ROI4:MinX_RBV,YPOS=BL5C_:ROI4:MinY_RBV,XSIZE=BL5C_:ROI4:SizeX_RBV,YSIZE=BL5C_:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template",   "P=BL5C_:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDColorConvert.template", "P=BL5C_:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1")
NDColorConvertConfigure("CC2", 20, 0, "PIL", 0, -1, -1)
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template",   "P=BL5C_:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDColorConvert.template", "P=BL5C_:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1")
# Load scan records
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/sscan-2-7/sscanApp/Db/scan.db", "P=BL5C_:,MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
set_requestfile_path("./")
set_requestfile_path("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db")
set_requestfile_path("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/sscan-2-7/sscanApp/Db")
set_savefile_path("./autosave")
Autosave is not configured to manage the file-system mount point.
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("BL5C_:")
dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/autosave-4-8/asApp/Db/save_restoreStatus.db", "P=BL5C_:")
asynSetTraceMask("PIL",0,255)
asynSetTraceMask("PIL",0,3)
iocInit()
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Jan 22 2014
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore (v4.12): entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore: Can't open file './autosave/auto_settings.sav'.
save_restore: Trying backup file './autosave/auto_settings.savB'
save_restore: Can't open file './autosave/auto_settings.savB'.
save_restore: Can't figure out which seq file is most recent,
save_restore: so I'm just going to start with './autosave/auto_settings.sav0'.
save_restore: Trying backup file './autosave/auto_settings.sav0'
save_restore: Can't open file './autosave/auto_settings.sav0'.
save_restore: Trying backup file './autosave/auto_settings.sav1'
save_restore: Can't open file './autosave/auto_settings.sav1'.
save_restore: Trying backup file './autosave/auto_settings.sav2'
save_restore: Can't open file './autosave/auto_settings.sav2'.
save_restore: Can't find a file to restore from...save_restore: ...last tried './autosave/auto_settings.sav2'. I give up.
save_restore: **********************************
save_restore: Can't open save file.2016/01/25 18:08:18.717 asynInt32SyncIO read: 0
2016/01/25 18:08:18.717 asynInt32SyncIO read: 487
2016/01/25 18:08:18.717 asynInt32SyncIO read: 195
2016/01/25 18:08:18.719 asynInt32SyncIO read: 0
2016/01/25 18:08:18.719 asynInt32SyncIO read: 5
2016/01/25 18:08:18.719 asynInt32SyncIO read: 2
2016/01/25 18:08:18.722 asynInt32SyncIO read: 0
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
save_restore: Can't open save file.iocRun: All initialization complete
# # save things every thirty seconds
# # create_monitor_set("auto_settings.req", 30,"P=$(PREFIX),D=cam1:")
epics> 2016/01/25 18:08:20.232 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2016/01/25 18:08:21.233 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2016/01/25 18:08:22.235 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2016/01/25 18:08:23.256 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2016/01/25 18:08:24.276 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeX_RBV devAsynInt32::interruptCallbackInput new value=487
2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeY_RBV devAsynInt32::interruptCallbackInput new value=195
2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeZ_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:ArraySize_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:DataType_RBV devAsynInt32::interruptCallbackInput new value=5
2016/01/25 18:08:24.276 BL5C_:cam1:ColorMode_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:ArrayCounter_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:WriteFile devAsynBusy::interruptCallback new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:WriteFile_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:ReadFile devAsynBusy::interruptCallback new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeX_RBV devAsynInt32::getCallbackValue from ringBuffer value=487
2016/01/25 18:08:24.276 BL5C_:cam1:ReadFile_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:Capture devAsynBusy::interruptCallback new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:Capture_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:WriteStatus devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:NumCaptured_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:MaxSizeX_RBV devAsynInt32::interruptCallbackInput new value=487
2016/01/25 18:08:24.276 BL5C_:cam1:MaxSizeY_RBV devAsynInt32::interruptCallbackInput new value=195
2016/01/25 18:08:24.276 BL5C_:cam1:DetectorState_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:NumImagesCounter_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:NumExposuresCounter_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:TimeRemaining_RBV devAsynFloat64::interruptCallbackInput new value=0.000000
2016/01/25 18:08:24.276 BL5C_:cam1:ShutterStatus_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:Acquire devAsynBusy::interruptCallback new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:Acquire_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:SizeX_RBV devAsynInt32::interruptCallbackInput new value=487
2016/01/25 18:08:24.276 BL5C_:cam1:SizeY_RBV devAsynInt32::interruptCallbackInput new value=195
2016/01/25 18:08:24.276 BL5C_:cam1:ImageMode_RBV devAsynInt32::interruptCallbackInput new value=2
2016/01/25 18:08:24.276 BL5C_:cam1:TriggerMode_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:Armed devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:NumBadPixels devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.276 BL5C_:cam1:FlatFieldValid devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:24.277 BL5C_:cam1:AcquirePeriod_RBV devAsynFloat64::interruptCallbackInput new value=0.000000
2016/01/25 18:08:24.277 BL5C_:cam1:NumExposures_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:24.277 BL5C_:cam1:NumImages_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:24.277 BL5C_:cam1:AcquireTime_RBV devAsynFloat64::interruptCallbackInput new value=1.000000
2016/01/25 18:08:24.277 BL5C_:cam1:DelayTime_RBV devAsynFloat64::interruptCallbackInput new value=0.000000
2016/01/25 18:08:24.277 BL5C_:cam1:GapFill_RBV devAsynInt32::interruptCallbackInput new value=-2
2016/01/25 18:08:24.277 BL5C_:cam1:AcquirePeriod devAsynFloat64 process val 0.000000
2016/01/25 18:08:24.277 BL5C_:cam1:ArraySizeY_RBV devAsynInt32::getCallbackValue from ringBuffer value=195
2016/01/25 18:08:24.277 BL5C_:cam1:ArraySizeZ_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:ArraySize_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:DataType_RBV devAsynInt32::getCallbackValue from ringBuffer value=5
2016/01/25 18:08:24.277 BL5C_:cam1:ColorMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:ArrayCounter_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:WriteFile_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:ReadFile_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:Capture_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:WriteStatus devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:NumCaptured_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:MaxSizeX_RBV devAsynInt32::getCallbackValue from ringBuffer value=487
2016/01/25 18:08:24.277 BL5C_:cam1:MaxSizeY_RBV devAsynInt32::getCallbackValue from ringBuffer value=195
2016/01/25 18:08:24.277 BL5C_:cam1:DetectorState_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:NumImagesCounter_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:NumExposuresCounter_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:TimeRemaining_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000
2016/01/25 18:08:24.277 BL5C_:cam1:ShutterStatus_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:Acquire_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:SizeX_RBV devAsynInt32::getCallbackValue from ringBuffer value=487
2016/01/25 18:08:24.277 BL5C_:cam1:SizeY_RBV devAsynInt32::getCallbackValue from ringBuffer value=195
2016/01/25 18:08:24.277 BL5C_:cam1:ImageMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=2
2016/01/25 18:08:24.277 BL5C_:cam1:TriggerMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:Armed devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:NumBadPixels devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:FlatFieldValid devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:24.277 BL5C_:cam1:AcquirePeriod_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000
2016/01/25 18:08:24.277 BL5C_:cam1:NumExposures_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:24.277 BL5C_:cam1:NumImages_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:24.277 BL5C_:cam1:AcquireTime_RBV devAsynFloat64::getCallbackValue from ringBuffer value=1.000000
2016/01/25 18:08:24.277 BL5C_:cam1:DelayTime_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000
2016/01/25 18:08:24.277 BL5C_:cam1:GapFill_RBV devAsynInt32::getCallbackValue from ringBuffer value=-2
2016/01/25 18:08:25.295 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes
2016/01/25 18:08:25.295 BL5C_:cam1:OscillAxis devAsynOctet: writeIt
2016/01/25 18:08:25.295 BL5C_:cam1:BadPixelFile devAsynOctet: writeIt
2016/01/25 18:08:25.296 BL5C_:cam1:FileName devAsynOctet: writeIt
2016/01/25 18:08:25.753 BL5C_:cam1:FilePath devAsynOctet: writeIt
2016/01/25 18:08:25.753 BL5C_:cam1:FileTemplate devAsynOctet: writeIt
2016/01/25 18:08:25.753 BL5C_:cam1:FlatFieldFile devAsynOctet: writeIt
2016/01/25 18:08:25.753 BL5C_:cam1:NDAttributesFile devAsynOctet: writeIt
2016/01/25 18:08:25.758 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period
2016/01/25 18:08:25.759 BL5C_:cam1:AcquireTime devAsynFloat64 process val 1.000000
2016/01/25 18:08:25.759 BL5C_:cam1:Alpha devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.760 BL5C_:cam1:AngleIncr devAsynFloat64 process val 0.100000
2016/01/25 18:08:25.760 BL5C_:cam1:BeamX devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.760 BL5C_:cam1:BeamY devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.761 BL5C_:cam1:Chi devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.765 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period
2016/01/25 18:08:25.766 BL5C_:cam1:DelayTime devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.767 BL5C_:cam1:Det2theta devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.767 BL5C_:cam1:DetDist devAsynFloat64 process val 1000.000000
2016/01/25 18:08:25.767 BL5C_:cam1:DetVOffset devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.768 BL5C_:cam1:EnergyHigh devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.768 BL5C_:cam1:EnergyLow devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.768 BL5C_:cam1:FilterTransm devAsynFloat64 process val 1.000000
2016/01/25 18:08:25.769 BL5C_:cam1:Flux devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.769 BL5C_:cam1:Gain_RBV devAsynFloat64::interruptCallbackInput new value=1.000000
2016/01/25 18:08:25.769 BL5C_:cam1:Gain devAsynFloat64 process val 1.000000
2016/01/25 18:08:25.769 BL5C_:cam1:Gain_RBV devAsynFloat64::getCallbackValue from ringBuffer value=1.000000
2016/01/25 18:08:25.769 BL5C_:cam1:ImageFileTmot devAsynFloat64 process val 20.000000
2016/01/25 18:08:25.769 BL5C_:cam1:Kappa devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:Phi devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:Polarization devAsynFloat64 process val 0.990000
2016/01/25 18:08:25.770 BL5C_:cam1:ShutterCloseDelay_RBV devAsynFloat64::interruptCallbackInput new value=0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:ShutterCloseDelay devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:ShutterOpenDelay_RBV devAsynFloat64::interruptCallbackInput new value=0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:ShutterOpenDelay devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:ShutterCloseDelay_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:ShutterOpenDelay_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:StartAngle devAsynFloat64 process val 0.000000
2016/01/25 18:08:25.770 BL5C_:cam1:Temperature_RBV devAsynFloat64::interruptCallbackInput new value=25.000000
2016/01/25 18:08:25.770 BL5C_:cam1:Temperature devAsynFloat64 process val 25.000000
2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdEnergy_RBV devAsynFloat64::interruptCallbackInput new value=10.000000
2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdEnergy devAsynFloat64 process val 10.000000
2016/01/25 18:08:25.771 BL5C_:cam1:Temperature_RBV devAsynFloat64::getCallbackValue from ringBuffer value=25.000000
2016/01/25 18:08:25.771 BL5C_:cam1:ArrayCallbacks_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:ArrayCallbacks devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:AutoIncrement_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:AutoIncrement devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:AutoSave_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:AutoSave devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:DeleteDriverFile_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:DeleteDriverFile devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:ReverseX_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:ReverseX devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:ReverseY_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:ReverseY devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:ShutterControl_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:ShutterControl devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdAutoApply_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdAutoApply devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:BinX_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:BinX devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:BinY_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:BinY devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:FileNumber_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:FileNumber_write devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:MinFlatField_RBV devAsynInt32::interruptCallbackInput new value=100
2016/01/25 18:08:25.771 BL5C_:cam1:MinFlatField devAsynInt32 process value 100
2016/01/25 18:08:25.771 BL5C_:cam1:MinX_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:MinX devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:MinY_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.771 BL5C_:cam1:MinY devAsynInt32 process value 0
2016/01/25 18:08:25.771 BL5C_:cam1:NumCapture_RBV devAsynInt32::interruptCallbackInput new value=1
2016/01/25 18:08:25.771 BL5C_:cam1:NumCapture devAsynInt32 process value 1
2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdEnergy_RBV devAsynFloat64::getCallbackValue from ringBuffer value=10.000000
2016/01/25 18:08:25.772 BL5C_:cam1:ArrayCallbacks_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:AutoIncrement_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.772 BL5C_:cam1:AutoSave_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.772 BL5C_:cam1:DeleteDriverFile_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:ReverseX_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:ReverseY_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:ShutterControl_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:ThresholdAutoApply_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.772 BL5C_:cam1:BinX_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.772 BL5C_:cam1:BinY_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.772 BL5C_:cam1:FileNumber_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.772 BL5C_:cam1:MinFlatField_RBV devAsynInt32::getCallbackValue from ringBuffer value=100
2016/01/25 18:08:25.772 BL5C_:cam1:MinX_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:MinY_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.772 BL5C_:cam1:NumCapture_RBV devAsynInt32::getCallbackValue from ringBuffer value=1
2016/01/25 18:08:25.773 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period
2016/01/25 18:08:25.774 BL5C_:cam1:NumExposures devAsynInt32 process value 1
2016/01/25 18:08:25.779 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period
2016/01/25 18:08:25.780 BL5C_:cam1:NumImages devAsynInt32 process value 1
2016/01/25 18:08:25.780 BL5C_:cam1:NumOscill devAsynInt32 process value 1
2016/01/25 18:08:25.780 BL5C_:cam1:SizeX devAsynInt32 process value 487
2016/01/25 18:08:25.780 BL5C_:cam1:SizeY devAsynInt32 process value 195
2016/01/25 18:08:25.780 BL5C_:cam1:ColorMode devAsynInt32 process value 0
2016/01/25 18:08:25.780 BL5C_:cam1:DataType devAsynInt32 process value 5
2016/01/25 18:08:25.780 BL5C_:cam1:FileFormat_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.780 BL5C_:cam1:FileFormat devAsynInt32 process value 0
2016/01/25 18:08:25.780 BL5C_:cam1:FileWriteMode_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.780 BL5C_:cam1:FileWriteMode devAsynInt32 process value 0
2016/01/25 18:08:25.780 BL5C_:cam1:FrameType_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.780 BL5C_:cam1:FrameType devAsynInt32 process value 0
2016/01/25 18:08:25.780 BL5C_:cam1:FileFormat_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.780 BL5C_:cam1:FileWriteMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.781 BL5C_:cam1:FrameType_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.785 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period
2016/01/25 18:08:25.786 BL5C_:cam1:GapFill_RBV devAsynInt32::interruptCallbackInput new value=-2
2016/01/25 18:08:25.786 BL5C_:cam1:GapFill devAsynInt32 process value 2
2016/01/25 18:08:25.786 BL5C_:cam1:ImageMode devAsynInt32 process value 2
2016/01/25 18:08:25.786 BL5C_:cam1:ShutterMode_RBV devAsynInt32::interruptCallbackInput new value=0
2016/01/25 18:08:25.786 BL5C_:cam1:ShutterMode devAsynInt32 process value 0
2016/01/25 18:08:25.786 BL5C_:cam1:GapFill_RBV devAsynInt32::getCallbackValue from ringBuffer value=-2
2016/01/25 18:08:25.786 BL5C_:cam1:ShutterMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0
2016/01/25 18:08:25.792 BL5C_:cam1:TriggerMode devAsynInt32 process value 0
Pilatus Detector.. IOC NO Response mujin park
Prev: Pilatus Detector.. IOC NO Response mujin park
Next: BOY Linking Container doesn't support OPI Search Path? Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
