Hello.. We use Pilatus Detector...In first time, it worked... but when i restarted... ------------------------------------------------------------------------------------------------- 2016/01/25 18:08:25.791 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period ---------------------------------------------------------------------------------------------- this message is... i don't know What is problem.. the camserver is alive (it is OK in ping test) < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocPilatus") epicsEnvSet("TOP","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1") epicsEnvSet("SUPPORT","/usr/local/epics/R3.14.12/modules/synApps_5_6/support") epicsEnvSet("ASYN","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/asyn-4-18") epicsEnvSet("CALC","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/calc-2-9") epicsEnvSet("BUSY","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/busy-1-4") epicsEnvSet("SSCAN","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/sscan-2-7") epicsEnvSet("MCA","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1") epicsEnvSet("AUTOSAVE","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/autosave-4-8") epicsEnvSet("AREA_DETECTOR","/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1") epicsEnvSet("EPICS_BASE","/usr/local/epics/R3.14.12/base") errlogInit(20000) dbLoadDatabase("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/dbd/pilatusDetectorApp.dbd") pilatusDetectorApp_registerRecordDeviceDriver(pdbbase) epicsEnvSet("EPICS_CA_SERVER_PORT", 6064) epicsEnvSet("EPICS_CA_REPEATER_PORT", 6065) epicsEnvSet("PREFIX", "BL5C_:") epicsEnvSet("PORT", "PIL") epicsEnvSet("QSIZE", "20") epicsEnvSet("XSIZE", "487") epicsEnvSet("YSIZE", "195") epicsEnvSet("NCHANS", "2048") epicsEnvSet("CAMSERVER", "10.0.1.100") ### # Create the asyn port to talk to the Pilatus on port 41234. drvAsynIPPortConfigure("camserver","10.0.1.100:41234") # Set the input and output terminators. asynOctetSetInputEos("camserver", 0, "\030") asynOctetSetOutputEos("camserver", 0, "\n") pilatusDetectorConfig("PIL", "camserver", 487, 195, 50, 200000000) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/ADBase.template", "P=BL5C_:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/pilatus.template","P=BL5C_:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver") # Create a standard arrays plugin NDStdArraysConfigure("Image1", 5, 0, "PIL", 0, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStdArrays.template", "P=BL5C_:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=94965") # Load all other plugins using commonPlugins.cmd < ../commonPlugins.cmd # Create a netCDF file saving plugin. NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "PIL", 0) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileNetCDF.template","P=BL5C_:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1") # Create a TIFF file saving plugin NDFileTIFFConfigure("FileTIFF1", 20, 0, "PIL", 0) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileTIFF.template", "P=BL5C_:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1") # Create a JPEG file saving plugin NDFileJPEGConfigure("FileJPEG1", 20, 0, "PIL", 0) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileJPEG.template", "P=BL5C_:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1") # Create a NeXus file saving plugin NDFileNexusConfigure("FileNexus1", 20, 0, "PIL", 0) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileNexus.template", "P=BL5C_:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1") # Create an HDF5 file saving plugin NDFileHDF5Configure("FileHDF1", 20, 0, "PIL", 0) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileHDF5.template", "P=BL5C_:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1") # Create a Magick file saving plugin NDFileMagickConfigure("FileMagick1", 20, 0, "PIL", 0) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFile.template", "P=BL5C_:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDFileMagick.template","P=BL5C_:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1") # Create 4 ROI plugins NDROIConfigure("ROI1", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template", "P=BL5C_:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1") NDROIConfigure("ROI2", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template", "P=BL5C_:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1") NDROIConfigure("ROI3", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template", "P=BL5C_:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1") NDROIConfigure("ROI4", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDROI.template", "P=BL5C_:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1") # Create a processing plugin NDProcessConfigure("PROC1", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDProcess.template", "P=BL5C_:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1") # Create 5 statistics plugins NDStatsConfigure("STATS1", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI1,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template", "P=BL5C_:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195") NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI2,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template", "P=BL5C_:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195") NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI3,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template", "P=BL5C_:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195") NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI4,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template", "P=BL5C_:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195") NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDStats.template", "P=BL5C_:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=487,YSIZE=195") # Create "fastSweep" drivers for the MCA record to do on-the-fly scanning of Stats data initFastSweep("SweepTotal1", "STATS1", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepNet1", "STATS1", 1, 2048, "NET_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepTotal2", "STATS2", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepNet2", "STATS2", 1, 2048, "NET_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepTotal3", "STATS3", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepNet3", "STATS3", 1, 2048, "NET_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepTotal4", "STATS4", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepNet4", "STATS4", 1, 2048, "NET_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepTotal5", "STATS5", 1, 2048, "TOTAL_ARRAY", "CALLBACK_PERIOD") initFastSweep("SweepNet5", "STATS5", 1, 2048, "NET_ARRAY", "CALLBACK_PERIOD") # Load MCA records for the fast sweep drivers dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats1:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal1 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats2:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal2 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats3:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal3 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats4:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal4 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats5:TotalArray,DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepTotal5 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats1:NetArray, DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet1 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats2:NetArray, DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet2 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats3:NetArray, DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet3 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats4:NetArray, DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet4 0)") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/mca-7-1/mcaApp/Db/mca.db", "P=BL5C_:,M=Stats5:NetArray, DTYP=asynMCA,NCHAN=2048,INP=@asyn(SweepNet5 0)") # Create a transform plugin NDTransformConfigure("TRANS1", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDTransform.template", "P=BL5C_:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1") # Create an overlay plugin with 8 overlays NDOverlayConfigure("OVER1", 20, 0, "PIL", 0, 8, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template","P=BL5C_:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlay.template", "P=BL5C_:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=BL5C_:ROI1:MinX_RBV,YPOS=BL5C_:ROI1:MinY_RBV,XSIZE=BL5C_:ROI1:SizeX_RBV,YSIZE=BL5C_:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:2:,NAME=ROI2, SHAPE=1,O=Over1:,XPOS=BL5C_:ROI2:MinX_RBV,YPOS=BL5C_:ROI2:MinY_RBV,XSIZE=BL5C_:ROI2:SizeX_RBV,YSIZE=BL5C_:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:3:,NAME=ROI3, SHAPE=1,O=Over1:,XPOS=BL5C_:ROI3:MinX_RBV,YPOS=BL5C_:ROI3:MinY_RBV,XSIZE=BL5C_:ROI3:SizeX_RBV,YSIZE=BL5C_:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:4:,NAME=ROI4, SHAPE=1,O=Over1:,XPOS=BL5C_:ROI4:MinX_RBV,YPOS=BL5C_:ROI4:MinY_RBV,XSIZE=BL5C_:ROI4:SizeX_RBV,YSIZE=BL5C_:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=4,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=5,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:7:,NAME=Box1, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=6,TIMEOUT=1") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDOverlayN.template","P=BL5C_:,R=Over1:8:,NAME=Box2, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=7,TIMEOUT=1") # Create 2 color conversion plugins NDColorConvertConfigure("CC1", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template", "P=BL5C_:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDColorConvert.template", "P=BL5C_:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1") NDColorConvertConfigure("CC2", 20, 0, "PIL", 0, -1, -1) dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDPluginBase.template", "P=BL5C_:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NDARRAY_ADDR=0") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db/NDColorConvert.template", "P=BL5C_:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1") # Load scan records dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/sscan-2-7/sscanApp/Db/scan.db", "P=BL5C_:,MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10") set_requestfile_path("./") set_requestfile_path("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/areaDetector-1-8beta1/ADApp/Db") set_requestfile_path("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/sscan-2-7/sscanApp/Db") set_savefile_path("./autosave") Autosave is not configured to manage the file-system mount point. set_pass0_restoreFile("auto_settings.sav") set_pass1_restoreFile("auto_settings.sav") save_restoreSet_status_prefix("BL5C_:") dbLoadRecords("/usr/local/epics/R3.14.12/modules/synApps_5_6/support/autosave-4-8/asApp/Db/save_restoreStatus.db", "P=BL5C_:") asynSetTraceMask("PIL",0,255) asynSetTraceMask("PIL",0,3) iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$ ## EPICS Base built Jan 22 2014 ############################################################################ reboot_restore: entry for file 'auto_settings.sav' reboot_restore (v4.12): entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) *** save_restore: Can't open file './autosave/auto_settings.sav'. save_restore: Trying backup file './autosave/auto_settings.savB' save_restore: Can't open file './autosave/auto_settings.savB'. save_restore: Can't figure out which seq file is most recent, save_restore: so I'm just going to start with './autosave/auto_settings.sav0'. save_restore: Trying backup file './autosave/auto_settings.sav0' save_restore: Can't open file './autosave/auto_settings.sav0'. save_restore: Trying backup file './autosave/auto_settings.sav1' save_restore: Can't open file './autosave/auto_settings.sav1'. save_restore: Trying backup file './autosave/auto_settings.sav2' save_restore: Can't open file './autosave/auto_settings.sav2'. save_restore: Can't find a file to restore from...save_restore: ...last tried './autosave/auto_settings.sav2'. I give up. save_restore: ********************************** save_restore: Can't open save file.2016/01/25 18:08:18.717 asynInt32SyncIO read: 0 2016/01/25 18:08:18.717 asynInt32SyncIO read: 487 2016/01/25 18:08:18.717 asynInt32SyncIO read: 195 2016/01/25 18:08:18.719 asynInt32SyncIO read: 0 2016/01/25 18:08:18.719 asynInt32SyncIO read: 5 2016/01/25 18:08:18.719 asynInt32SyncIO read: 2 2016/01/25 18:08:18.719 asynInt32SyncIO read: 0 2016/01/25 18:08:18.722 asynInt32SyncIO read: 0 2016/01/25 18:08:18.722 asynInt32SyncIO read: 0 2016/01/25 18:08:18.722 asynInt32SyncIO read: 0 2016/01/25 18:08:18.722 asynInt32SyncIO read: 0 reboot_restore: entry for file 'auto_settings.sav' reboot_restore (v4.12): entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) *** save_restore: Can't open file './autosave/auto_settings.sav'. save_restore: Trying backup file './autosave/auto_settings.savB' save_restore: Can't open file './autosave/auto_settings.savB'. save_restore: Can't figure out which seq file is most recent, save_restore: so I'm just going to start with './autosave/auto_settings.sav0'. save_restore: Trying backup file './autosave/auto_settings.sav0' save_restore: Can't open file './autosave/auto_settings.sav0'. save_restore: Trying backup file './autosave/auto_settings.sav1' save_restore: Can't open file './autosave/auto_settings.sav1'. save_restore: Trying backup file './autosave/auto_settings.sav2' save_restore: Can't open file './autosave/auto_settings.sav2'. save_restore: Can't find a file to restore from...save_restore: ...last tried './autosave/auto_settings.sav2'. I give up. save_restore: ********************************** save_restore: Can't open save file.iocRun: All initialization complete # # # save things every thirty seconds # # create_monitor_set("auto_settings.req", 30,"P=$(PREFIX),D=cam1:") epics> 2016/01/25 18:08:20.232 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes 2016/01/25 18:08:21.233 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes 2016/01/25 18:08:22.235 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes 2016/01/25 18:08:23.256 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes 2016/01/25 18:08:24.276 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes 2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeX_RBV devAsynInt32::interruptCallbackInput new value=487 2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeY_RBV devAsynInt32::interruptCallbackInput new value=195 2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeZ_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:ArraySize_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:DataType_RBV devAsynInt32::interruptCallbackInput new value=5 2016/01/25 18:08:24.276 BL5C_:cam1:ColorMode_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:ArrayCounter_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:WriteFile devAsynBusy::interruptCallback new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:WriteFile_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:ReadFile devAsynBusy::interruptCallback new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:ArraySizeX_RBV devAsynInt32::getCallbackValue from ringBuffer value=487 2016/01/25 18:08:24.276 BL5C_:cam1:ReadFile_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:Capture devAsynBusy::interruptCallback new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:Capture_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:WriteStatus devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:NumCaptured_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:MaxSizeX_RBV devAsynInt32::interruptCallbackInput new value=487 2016/01/25 18:08:24.276 BL5C_:cam1:MaxSizeY_RBV devAsynInt32::interruptCallbackInput new value=195 2016/01/25 18:08:24.276 BL5C_:cam1:DetectorState_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:NumImagesCounter_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:NumExposuresCounter_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:TimeRemaining_RBV devAsynFloat64::interruptCallbackInput new value=0.000000 2016/01/25 18:08:24.276 BL5C_:cam1:ShutterStatus_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:Acquire devAsynBusy::interruptCallback new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:Acquire_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:SizeX_RBV devAsynInt32::interruptCallbackInput new value=487 2016/01/25 18:08:24.276 BL5C_:cam1:SizeY_RBV devAsynInt32::interruptCallbackInput new value=195 2016/01/25 18:08:24.276 BL5C_:cam1:ImageMode_RBV devAsynInt32::interruptCallbackInput new value=2 2016/01/25 18:08:24.276 BL5C_:cam1:TriggerMode_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:Armed devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:NumBadPixels devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.276 BL5C_:cam1:FlatFieldValid devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:24.277 BL5C_:cam1:AcquirePeriod_RBV devAsynFloat64::interruptCallbackInput new value=0.000000 2016/01/25 18:08:24.277 BL5C_:cam1:NumExposures_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:24.277 BL5C_:cam1:NumImages_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:24.277 BL5C_:cam1:AcquireTime_RBV devAsynFloat64::interruptCallbackInput new value=1.000000 2016/01/25 18:08:24.277 BL5C_:cam1:DelayTime_RBV devAsynFloat64::interruptCallbackInput new value=0.000000 2016/01/25 18:08:24.277 BL5C_:cam1:GapFill_RBV devAsynInt32::interruptCallbackInput new value=-2 2016/01/25 18:08:24.277 BL5C_:cam1:AcquirePeriod devAsynFloat64 process val 0.000000 2016/01/25 18:08:24.277 BL5C_:cam1:ArraySizeY_RBV devAsynInt32::getCallbackValue from ringBuffer value=195 2016/01/25 18:08:24.277 BL5C_:cam1:ArraySizeZ_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:ArraySize_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:DataType_RBV devAsynInt32::getCallbackValue from ringBuffer value=5 2016/01/25 18:08:24.277 BL5C_:cam1:ColorMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:ArrayCounter_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:WriteFile_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:ReadFile_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:Capture_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:WriteStatus devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:NumCaptured_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:MaxSizeX_RBV devAsynInt32::getCallbackValue from ringBuffer value=487 2016/01/25 18:08:24.277 BL5C_:cam1:MaxSizeY_RBV devAsynInt32::getCallbackValue from ringBuffer value=195 2016/01/25 18:08:24.277 BL5C_:cam1:DetectorState_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:NumImagesCounter_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:NumExposuresCounter_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:TimeRemaining_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000 2016/01/25 18:08:24.277 BL5C_:cam1:ShutterStatus_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:Acquire_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:SizeX_RBV devAsynInt32::getCallbackValue from ringBuffer value=487 2016/01/25 18:08:24.277 BL5C_:cam1:SizeY_RBV devAsynInt32::getCallbackValue from ringBuffer value=195 2016/01/25 18:08:24.277 BL5C_:cam1:ImageMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=2 2016/01/25 18:08:24.277 BL5C_:cam1:TriggerMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:Armed devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:NumBadPixels devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:FlatFieldValid devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:24.277 BL5C_:cam1:AcquirePeriod_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000 2016/01/25 18:08:24.277 BL5C_:cam1:NumExposures_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:24.277 BL5C_:cam1:NumImages_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:24.277 BL5C_:cam1:AcquireTime_RBV devAsynFloat64::getCallbackValue from ringBuffer value=1.000000 2016/01/25 18:08:24.277 BL5C_:cam1:DelayTime_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000 2016/01/25 18:08:24.277 BL5C_:cam1:GapFill_RBV devAsynInt32::getCallbackValue from ringBuffer value=-2 2016/01/25 18:08:25.295 pilatusDetector:readCamserver, timeout=1.000000, status=1 received 0 bytes 2016/01/25 18:08:25.295 BL5C_:cam1:OscillAxis devAsynOctet: writeIt 2016/01/25 18:08:25.295 BL5C_:cam1:BadPixelFile devAsynOctet: writeIt 2016/01/25 18:08:25.296 BL5C_:cam1:FileName devAsynOctet: writeIt 2016/01/25 18:08:25.753 BL5C_:cam1:FilePath devAsynOctet: writeIt 2016/01/25 18:08:25.753 BL5C_:cam1:FileTemplate devAsynOctet: writeIt 2016/01/25 18:08:25.753 BL5C_:cam1:FlatFieldFile devAsynOctet: writeIt 2016/01/25 18:08:25.753 BL5C_:cam1:NDAttributesFile devAsynOctet: writeIt 2016/01/25 18:08:25.758 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period 2016/01/25 18:08:25.759 BL5C_:cam1:AcquireTime devAsynFloat64 process val 1.000000 2016/01/25 18:08:25.759 BL5C_:cam1:Alpha devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.760 BL5C_:cam1:AngleIncr devAsynFloat64 process val 0.100000 2016/01/25 18:08:25.760 BL5C_:cam1:BeamX devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.760 BL5C_:cam1:BeamY devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.761 BL5C_:cam1:Chi devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.765 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period 2016/01/25 18:08:25.766 BL5C_:cam1:DelayTime devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.767 BL5C_:cam1:Det2theta devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.767 BL5C_:cam1:DetDist devAsynFloat64 process val 1000.000000 2016/01/25 18:08:25.767 BL5C_:cam1:DetVOffset devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.768 BL5C_:cam1:EnergyHigh devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.768 BL5C_:cam1:EnergyLow devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.768 BL5C_:cam1:FilterTransm devAsynFloat64 process val 1.000000 2016/01/25 18:08:25.769 BL5C_:cam1:Flux devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.769 BL5C_:cam1:Gain_RBV devAsynFloat64::interruptCallbackInput new value=1.000000 2016/01/25 18:08:25.769 BL5C_:cam1:Gain devAsynFloat64 process val 1.000000 2016/01/25 18:08:25.769 BL5C_:cam1:Gain_RBV devAsynFloat64::getCallbackValue from ringBuffer value=1.000000 2016/01/25 18:08:25.769 BL5C_:cam1:ImageFileTmot devAsynFloat64 process val 20.000000 2016/01/25 18:08:25.769 BL5C_:cam1:Kappa devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:Phi devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:Polarization devAsynFloat64 process val 0.990000 2016/01/25 18:08:25.770 BL5C_:cam1:ShutterCloseDelay_RBV devAsynFloat64::interruptCallbackInput new value=0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:ShutterCloseDelay devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:ShutterOpenDelay_RBV devAsynFloat64::interruptCallbackInput new value=0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:ShutterOpenDelay devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:ShutterCloseDelay_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:ShutterOpenDelay_RBV devAsynFloat64::getCallbackValue from ringBuffer value=0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:StartAngle devAsynFloat64 process val 0.000000 2016/01/25 18:08:25.770 BL5C_:cam1:Temperature_RBV devAsynFloat64::interruptCallbackInput new value=25.000000 2016/01/25 18:08:25.770 BL5C_:cam1:Temperature devAsynFloat64 process val 25.000000 2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdEnergy_RBV devAsynFloat64::interruptCallbackInput new value=10.000000 2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdEnergy devAsynFloat64 process val 10.000000 2016/01/25 18:08:25.771 BL5C_:cam1:Temperature_RBV devAsynFloat64::getCallbackValue from ringBuffer value=25.000000 2016/01/25 18:08:25.771 BL5C_:cam1:ArrayCallbacks_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:ArrayCallbacks devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:AutoIncrement_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:AutoIncrement devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:AutoSave_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:AutoSave devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:DeleteDriverFile_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:DeleteDriverFile devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:ReverseX_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:ReverseX devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:ReverseY_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:ReverseY devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:ShutterControl_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:ShutterControl devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdAutoApply_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdAutoApply devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:BinX_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:BinX devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:BinY_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:BinY devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:FileNumber_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:FileNumber_write devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:MinFlatField_RBV devAsynInt32::interruptCallbackInput new value=100 2016/01/25 18:08:25.771 BL5C_:cam1:MinFlatField devAsynInt32 process value 100 2016/01/25 18:08:25.771 BL5C_:cam1:MinX_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:MinX devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:MinY_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.771 BL5C_:cam1:MinY devAsynInt32 process value 0 2016/01/25 18:08:25.771 BL5C_:cam1:NumCapture_RBV devAsynInt32::interruptCallbackInput new value=1 2016/01/25 18:08:25.771 BL5C_:cam1:NumCapture devAsynInt32 process value 1 2016/01/25 18:08:25.771 BL5C_:cam1:ThresholdEnergy_RBV devAsynFloat64::getCallbackValue from ringBuffer value=10.000000 2016/01/25 18:08:25.772 BL5C_:cam1:ArrayCallbacks_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:AutoIncrement_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.772 BL5C_:cam1:AutoSave_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.772 BL5C_:cam1:DeleteDriverFile_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:ReverseX_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:ReverseY_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:ShutterControl_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:ThresholdAutoApply_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.772 BL5C_:cam1:BinX_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.772 BL5C_:cam1:BinY_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.772 BL5C_:cam1:FileNumber_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.772 BL5C_:cam1:MinFlatField_RBV devAsynInt32::getCallbackValue from ringBuffer value=100 2016/01/25 18:08:25.772 BL5C_:cam1:MinX_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:MinY_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.772 BL5C_:cam1:NumCapture_RBV devAsynInt32::getCallbackValue from ringBuffer value=1 2016/01/25 18:08:25.773 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period 2016/01/25 18:08:25.774 BL5C_:cam1:NumExposures devAsynInt32 process value 1 2016/01/25 18:08:25.779 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period 2016/01/25 18:08:25.780 BL5C_:cam1:NumImages devAsynInt32 process value 1 2016/01/25 18:08:25.780 BL5C_:cam1:NumOscill devAsynInt32 process value 1 2016/01/25 18:08:25.780 BL5C_:cam1:SizeX devAsynInt32 process value 487 2016/01/25 18:08:25.780 BL5C_:cam1:SizeY devAsynInt32 process value 195 2016/01/25 18:08:25.780 BL5C_:cam1:ColorMode devAsynInt32 process value 0 2016/01/25 18:08:25.780 BL5C_:cam1:DataType devAsynInt32 process value 5 2016/01/25 18:08:25.780 BL5C_:cam1:FileFormat_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.780 BL5C_:cam1:FileFormat devAsynInt32 process value 0 2016/01/25 18:08:25.780 BL5C_:cam1:FileWriteMode_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.780 BL5C_:cam1:FileWriteMode devAsynInt32 process value 0 2016/01/25 18:08:25.780 BL5C_:cam1:FrameType_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.780 BL5C_:cam1:FrameType devAsynInt32 process value 0 2016/01/25 18:08:25.780 BL5C_:cam1:FileFormat_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.780 BL5C_:cam1:FileWriteMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.781 BL5C_:cam1:FrameType_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.785 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period 2016/01/25 18:08:25.786 BL5C_:cam1:GapFill_RBV devAsynInt32::interruptCallbackInput new value=-2 2016/01/25 18:08:25.786 BL5C_:cam1:GapFill devAsynInt32 process value 2 2016/01/25 18:08:25.786 BL5C_:cam1:ImageMode devAsynInt32 process value 2 2016/01/25 18:08:25.786 BL5C_:cam1:ShutterMode_RBV devAsynInt32::interruptCallbackInput new value=0 2016/01/25 18:08:25.786 BL5C_:cam1:ShutterMode devAsynInt32 process value 0 2016/01/25 18:08:25.786 BL5C_:cam1:GapFill_RBV devAsynInt32::getCallbackValue from ringBuffer value=-2 2016/01/25 18:08:25.786 BL5C_:cam1:ShutterMode_RBV devAsynInt32::getCallbackValue from ringBuffer value=0 2016/01/25 18:08:25.791 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Illegal exposure period 2016/01/25 18:08:25.792 BL5C_:cam1:TriggerMode devAsynInt32 process value 0
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
