1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Re: Re:Re: Re:Re: EPICS Multiple Archiver Appliance problem
To: "Shankar, Murali" <[email protected]>
Cc: <[email protected]>
Date: Mon, 18 Jan 2016 04:08:11 +0000
I have modifed httpd.conf.  Like you said.
Metrics Page: http://node1:17665/mgmt/ui/metrics.html
Appliances Page: http://node1:17665/mgmt/ui/appliance.html
works very well and everything is OK.
But i don't understand about this.
Typo...
>> So, if the machine running Apache is called arch, your mgmt URL will be http://arch/mgmt/ui/index.html and your client_retrieval_url will be http://arch/retrieval
As i understand, i had to modify httpd.conf
here is the my httpd.conf file
ServerAdmin root@localhost
ServerName www.archappl.com:80(17665)
DocumentRoot "/var/www/html"
<Directory "/var/www/html">
and access http://archappl/mgmt/ui/index.html
but there is the message.. webpage is not available or not found server.
Thanks you very much for help
2016년 1월 14일 오후 05:41에 "Shankar, Murali" <[email protected]> 작성:
Typo...
I meant to say your data_retrieval_url will be http://arch/retrieval
Murali
Sent: Thursday, January 14, 2016 5:32 PM
To: Seung-hee Nam
Cc: [email protected]
Subject: Re: Re:Re: Re:Re: EPICS Multiple Archiver Appliance problem
You shouldn't need to do anything; try to access these URL's in a browser. If everything is working well, you should see two entries in the top table.
Appserver 2 should have the same behavior. So, this should also give you the same content
Metrics Page: http://node2:17665/mgmt/ui/metrics.html
Appliances Page: http://node2:17665/mgmt/ui/appliance.html
Please let me know if this is not the case.
To pop Apache in front of these two, you could use something like so in the httpd.conf.
# Enabling load balancing for mgmt
Header add Set-Cookie "ROUTEID=.%{BALANCER_WORKER_ROUTE}e; path=/" env=BALANCER_ROUTE_CHANGED
BalancerMember http://node1:17665/mgmt/ route=1
BalancerMember http://node2:17665/mgmt/ route=2
ProxySet stickysession=ROUTEID
ProxySet lbmethod=bybusyness
</Proxy>
ProxyPass /mgmt balancer://mgmt
# Enabling load balancing for retrieval
BalancerMember http://node1:17668/retrieval/ route=1
BalancerMember http://node2:17668/retrieval/ route=2
</Proxy>
ProxyPass /retrieval balancer://archiver
Please let me know if you need more info.
Murali
Sent: Thursday, January 14, 2016 5:21 PM
To: Shankar, Murali
Subject: Re:Re: Re:Re: EPICS Multiple Archiver Appliance problem
Oooooh.  I made a basic mistake.
I can thank you enough Murali. each appserver startup and works very well!
and i have another question. How configuring apache for metrics/appliances page??
2016년 1월 14일 오후 05:05에 "Shankar, Murali" <[email protected]> 작성:
Sorry --> hit send too early.
I think your appliances.xml is incorrect. You have an extra </appliances><appliances> in the middle. Here's what this should look like
<?xml version="1.0"?>
<appliances>
  <appliance>
    <identity>appliance0</identity>
    <cluster_inetport>node1:16670</cluster_inetport>
    <mgmt_url>http://node1:17665/mgmt/bpl</mgmt_url>
    <engine_url>http://node1:17666/engine/bpl</engine_url>
    <etl_url>http://node1:17667/etl/bpl</etl_url>
    <retrieval_url>http://node1:17668/retrieval/bpl</retrieval_url>
    <data_retrieval_url>http://archiver:17668/retrieval</data_retrieval_url>
  </appliance>
  <appliance>
    <identity>appliance1</identity>
    <cluster_inetport>node2:16670</cluster_inetport>
    <mgmt_url>http://node2:17665/mgmt/bpl</mgmt_url>
    <engine_url>http://node2:17666/engine/bpl</engine_url>
    <etl_url>http://node2:17667/etl/bpl</etl_url>
    <retrieval_url>http://node2:17668/retrieval/bpl</retrieval_url>
  </appliance>
</appliances>
You can validate the appliances.xml using xmllint. Would you be able to make this change and let me know if the appserver(s) start up?
Murali
Sent: Thursday, January 14, 2016 5:01 PM
To: Seung-hee Nam
Subject: Re: Re:Re: EPICS Multiple Archiver Appliance problem
​I think your appliances.xml is not valid XML.
Sent: Thursday, January 14, 2016 4:54 PM
To: Shankar, Murali
Subject: Re:Re: EPICS Multiple Archiver Appliance problem
Hi Murali.
Thanks you for your advise.
Still, i have a problem.. I have already changed appliance.xml and startup.sh, but it doesn't work.
here is the log. each node have same problem.
  • arch.log
0 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_SNAPSHOT_03-November-2015T18-04-14
2 [localhost-startStop-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService -
29 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
org.epics.archiverappliance.config.exception.ConfigException: Exception loading appliances.xml
at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:244)
at org.epics.archiverappliance.config.ArchServletContextListener.contextInitialized(ArchServletContextListener.java:41)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5003)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5517)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1095)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1960)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Exception parsing appliance.xml
at org.epics.archiverappliance.config.AppliancesList.loadAppliancesXML(AppliancesList.java:74)
at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:242)
... 14 more
Caused by: org.xml.sax.SAXParseException; lineNumber: 12; columnNumber: 3; The markup in the document following the root element must be well-formed.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:257)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:121)
at org.epics.archiverappliance.config.AppliancesList.loadAppliancesXML(AppliancesList.java:38)
... 15 more
  • catalina.err
Jan 15, 2016 9:43:22 AM org.apache.catalina.core.ApplicationContext log
INFO: ContextListener: contextInitialized()
INFO: SessionListener: contextInitialized()
INFO: ContextListener: attributeAdded('org.apache.jasper.compiler.TldLocationsCache', 'org.apache.jasper.compiler.TldLocationsCache@e68f736')
Jan 15, 2016 9:43:22 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory /root/archiver_appliance_node1/archiver_appliance/mgmt/webapps/examples has finished in 306 ms
Jan 15, 2016 9:43:22 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-17665"]
Jan 15, 2016 9:43:22 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 6291 ms
Jan 15, 2016 9:44:10 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception
java.lang.NullPointerException
at org.epics.archiverappliance.mgmt.MgmtUIFilter.doFilter(MgmtUIFilter.java:33)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
following is the details which i modified.
node1
  • appliances.xml
<appliances>
<appliance>
</appliance>
</appliances>
<appliances>
<appliance>
</appliance>
</appliances>
  • startup.sh
source /root/epics/R3.14.12.5/setEpicsEnv.sh
export JAVA_HOME=/opt/jdk1.8.0_66/
export PATH=${JAVA_HOME}/bin:${PATH}
export JAVA_OPTS="-XX:MaxPermSize=128M -XX:+UseG1GC -Xmx4G -Xms4G -ea"
export TOMCAT_HOME=/root/archiver_appliance_node1/archiver_appliance/apache-tomcat-7.0.65
export ARCHAPPL_DEPLOY_DIR=/root/archiver_appliance_node1/archiver_appliance
export ARCHAPPL_APPLIANCES=/root/archiver_appliance_node1/archiver_appliance/appliances.xml
export ARCHAPPL_MYIDENTITY="appliance0"
export ARCHAPPL_SHORT_TERM_FOLDER=/dev/shm/STS
export ARCHAPPL_MEDIUM_TERM_FOLDER=/root/archStorage/MTS
export ARCHAPPL_LONG_TERM_FOLDER=/GPFS/LTS
node2
  • appliances.xml
<appliances>
<appliance>
</appliance>
</appliances>
<appliances>
<appliance>
</appliance>
</appliances>
  • startup.sh
export TOMCAT_HOME=/root/archiver_appliance_node2/archiver_appliance/apache-tomcat-7.0.65
export ARCHAPPL_DEPLOY_DIR=/root/archiver_appliance_node2/archiver_appliance
export ARCHAPPL_APPLIANCES=/root/archiver_appliance_node2/archiver_appliance/appliances.xml
export ARCHAPPL_MYIDENTITY="appliance1"
I want to know how the multiple archiver appliance is configured by modifying the appliance.xml and startup.sh file. I think I need to run the two nodes at a time.
2016년 1월 14일 오후 01:56에 "Shankar, Murali" <[email protected]> 작성:
Hi Seung-hee,
>> But I have a problem with multiple archiver appliance configuration. I don't know how to access to the multiple archiver appliance configuration. Please give me advise or configuration way.
You should't have to do anything special; that is, you should be able to get data for PV's from both appliances on either appliance. Your appliance XML should have two sections; one for each appliances as outlined here - http://slacmshankar.github.io/epicsarchiver_docs/installguide.html#appliances_xmlYou can confirm if the appliances are seeing each other by looking at the Metrics/Appliances pages in the Web UI. You should see an entry in the top table for each appliance in your cluster.
If the metrics/appliances page shows both appliances; you are all set. In this case,  you can optionally pop an Apache/nginx instance in front to load balance and give clients a single URL as outlined in the same section. Please let me know if you need help configuring Apache here.
Murali
Re: Re: Re:Re: Re:Re: EPICS Multiple Archiver Appliance problem Shankar, Murali
Prev: Ethernet EPICS driver for F460 QBPM 김지화(빔라인장치팀)
Next: Re: Device Support for I2C and GPIO Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Ethernet EPICS driver for F460 QBPM Mark Rivers
Next: Re: Re: Re:Re: Re:Re: EPICS Multiple Archiver Appliance problem Shankar, Murali
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
