1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: areaDetector: ADBinX/Y and ADSizeX/Y interactions
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 15 Jan 2016 10:17:55 +0000
I'm afraid you're showing up my almost total ignorance of the EPICS record structure, so I'm going to have to retaliate by asking more questions.
ADBase.template has, for example:
record(mbbo, "$(P)$(R)FrameType")
   field(PINI, "YES")
   field(DTYP, "asynInt32")
   field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))FRAME_TYPE")
   field(ZRST, "Normal")
   field(ZRVL, "0")
   field(ONST, "Background")
   field(ONVL, "1")
   field(TWST, "FlatField")
   field(TWVL, "2")
   field(THST, "DblCorrelation")
   field(THVL, "3")
   field(VAL,  "0")
   info(autosaveFields, "VAL")
record(mbbi, "$(P)$(R)FrameType_RBV")
   field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))FRAME_TYPE")
   field(ZRVL, "0")
   field(ONVL, "1")
   field(TWVL, "2")
   field(THVL, "3")
   field(SCAN, "I/O Intr")
Are you saying that, if the mbbo record had the asyn:READBACK, the _RBV record would be unnecessary?  Since I've done them all now (or rather, written a utility that generates them all from a spreadsheet), is there any advantage in doing so?
Phil
On 14/01/2016 19:11, Mark Rivers wrote:
asyn:READBACK would be for the output records (e.g. ao, bo, mbbo, etc.), not the readback records.  The output records would then change value if you change the parameter in your driver.  The device support is smart enough to not call the driver again when the output record processes because of the callback.
Sent: Thursday, January 14, 2016 12:27 PM
To: Mark Rivers; [email protected]
At present my readback records have a field that says:
Is the asyn:Readback option an alternative or a possible addition?
Phil
On 14/01/2016 18:10, Mark Rivers wrote:
Hi Phil,
Ø  Out of interest: in the case of the CMOS cameras you choose to ignore the error rather than force the binning value to 1,
Ø  whereas if binning is set to less than one then you do change the value of the parameter.
Ø  Is there a 'philosophy' guideline you're applying there?
The actual value of the parameter being used should be set in the parameter library.  You make a good point, in this case the code should really be:
    s = PvAttrUint32Set(this->PvHandle, "BinningX", binX);
    if (s == ePvErrNotFound) {
        binX = 1;
        setIntegerParam(ADBinX, binX);
    } else status |= s;
    s = PvAttrUint32Set(this->PvHandle, "BinningY", binY);
        binY = 1;
        setIntegerParam(ADBinY, binY);
    } else status |= s;
Ø   (I'm still struggling with whether to provide _RBV database records for all settings, and when to change the parameter and when to just override it).
It is almost always a good idea to provide _RBV records so the user can see the parameter value actually being used by the driver in case it differs from the requested value.  It is also possible to make the output record update to reflect the new choice by setting the info tag asyn:READBACK in the database.  Sometimes this is desirable and sometimes it is not.
Sent: Thursday, January 14, 2016 11:57 AM
Thanks Mark.
Out of interest: in the case of the CMOS cameras you choose to ignore the error rather than force the binning value to 1, whereas if binning is set to less than one then you do change the value of the parameter.  Is there a 'philosophy' guideline you're applying there?  (I'm still struggling with whether to provide _RBV database records for all settings, and when to change the parameter and when to just override it).
Phil
On 14/01/2016 17:39, Mark Rivers wrote:
Hi Phil,
You are correct.
The units of ADSize are intended to be in unbinned detector pixels.  The ADProsilica::setGeometry is a good example.  Their API defines the readout region size in binned pixels, so the driver sets it to ADSizeX/ADBinX.  I can’t promise that all detector drivers have been written to follow this convention, but they should be.
Here is the code for the Prosilica driver.
asynStatus prosilica::setGeometry()
    int status = asynSuccess;
    int s;
    int binX, binY, minY, minX, sizeX, sizeY, maxSizeX, maxSizeY;
    static const char *functionName = "setGeometry";
    /* Get all of the current geometry parameters from the parameter library */
    status |= getIntegerParam(ADBinX, &binX);
    if (binX < 1) binX = 1;
    status |= getIntegerParam(ADBinY, &binY);
    if (binY < 1) binY = 1;
    status |= getIntegerParam(ADMinX, &minX);
    status |= getIntegerParam(ADMinY, &minY);
    status |= getIntegerParam(ADSizeX, &sizeX);
    status |= getIntegerParam(ADSizeY, &sizeY);
    status |= getIntegerParam(ADMaxSizeX, &maxSizeX);
    status |= getIntegerParam(ADMaxSizeY, &maxSizeY);
    if (minX + sizeX > maxSizeX) {
        sizeX = maxSizeX - minX;
        setIntegerParam(ADSizeX, sizeX);
    if (minY + sizeY > maxSizeY) {
        sizeY = maxSizeY - minY;
        setIntegerParam(ADSizeY, sizeY);
    /* CMOS cameras don't support binning, so ignore ePvErrNotFound errors */
    if (s != ePvErrNotFound) status |= s;
    if(!status){
      status |= PvAttrUint32Set(this->PvHandle, "RegionX", minX/binX);
      status |= PvAttrUint32Set(this->PvHandle, "RegionY", minY/binY);
      status |= PvAttrUint32Set(this->PvHandle, "Width",   sizeX/binX);
      status |= PvAttrUint32Set(this->PvHandle, "Height",  sizeY/binY);
    if (status) asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
                      "%s:%s: error, status=%d\n",
                      driverName, functionName, status);
    return((asynStatus)status);
From: [email protected] [mailto:[email protected]] On Behalf Of Phil Atkin
Sent: Thursday, January 14, 2016 9:40 AM
To: [email protected]
Subject: areaDetector: ADBinX/Y and ADSizeX/Y interactions
As I understand it, the ADSize parameters are intended to determine the dimensions of the _physical_ region of the sensor that is read out.  That's why the constraint imposed is
    ADMin + ADSize <= ADMaxSize
This means that the output array from an areaDetector driver should have dimensions given approximately by ADSize/ADBin for each dimension.
Is this correct?
Phil Atkin
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
areaDetector: ADBinX/Y and ADSizeX/Y interactions Phil Atkin
Re: areaDetector: ADBinX/Y and ADSizeX/Y interactions Phil Atkin
Prev: RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
Next: RE: Dynamically refresh CSS BOY runtime OPI will.rogers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
Next: RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
