Hi Seung-hee,
>> But I have a problem with multiple archiver appliance configuration. I don't know how to access to the multiple archiver appliance configuration. Please
give me advise or configuration way.
You should't have to do anything special; that is, you should be able to get data for PV's from both appliances on either appliance. Your appliance XML should have two sections; one for each appliances as outlined here - http://slacmshankar.github.io/epicsarchiver_docs/installguide.html#appliances_xml. You
can confirm if the appliances are seeing each other by looking at the Metrics/Appliances pages in the Web UI. You should see an entry in the top table for each appliance in your cluster.
If the metrics/appliances page shows both appliances; you are all set. In this case, you can optionally pop an Apache/nginx instance in front to load balance and give clients a single URL as outlined in the same section. Please let me know if you need help
configuring Apache here.
Murali
RE: Device Support for I2C and GPIO Mark Rivers
Re:Re: EPICS Multiple Archiver Appliance problem Seung-hee Nam
<2016>
EPICS Multiple Archiver Appliance problem Nam Seung-hee
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
