On 01/14/2016 10:59 AM, Lingyun Yang wrote:
> Thank you all for the help.
> Unfortunately this aSub is outputing both "calculation" and "action". So
> I want to forward the "calculations" but inhibit the actions.
> This all/none solutions does not work for me.
As long as your subroutine subsequently returns a non-zero value, you
can control which links get output yourself by calling dbPutLink()
yourself as desired. Take a look in the src/rec/aSubRecord.c file at the
process() routine, where you'll find this code:
> /* Push the output link values */
> if (!status) {
> int i;
> for (i = 0; i < NUM_ARGS; i++)
> dbPutLink(&(&prec->outa)[i], (&prec->ftva)[i], (&prec->vala)[i],
> (&prec->neva)[i]);
You just need to do exactly what the record does for each of the links
that you want to send out. This will probably be *much* easier than
using Kay's calcout suggestion.
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- Skip updating an output link in aSub ? Lingyun Yang
- Re: Skip updating an output link in aSub ? Michael Davidsaver
- Re: Skip updating an output link in aSub ? Andrew Johnson
- Re: Skip updating an output link in aSub ? Lingyun Yang
Re: Skip updating an output link in aSub ? Roehrig, Christian
<2016>
<2016>
