1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Skip updating an output link in aSub ?
To: Lingyun Yang <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 14 Jan 2016 11:44:20 +0000
I've got a couple places I've needed to do that with aSub, what's worked for me is having the C record processing code (the function specified in SNAM) return an error (-1) rather than success (0).  Then none of the output links are processed.
On 1/13/2016 5:55 PM, Lingyun Yang wrote:
I am writing a aSub routine to do some multiinput-multioutput data analysis.
In some cases, I do not want to update the output links. e.g. let those
OUTA-OUTU PVs values untouched.
If I do not do anything to the prec->vala to prec->valu, the corresponding PVs still get updated, but with some default values, e.g. 0.0 for DOUBLE.
I also tried to set effective length (e.g. set neva=0), but it did not work for an ao record.
Is there anyway skip updating any/some of the output PVs in the aSub routine ?
Thanks.
Best regards,
Lingyun
John A. Priller             | Phone : (517) 908-7375
MSU Cyclotron Laboratory    | Email : [email protected]
640 S. Shaw Lane room 4220Z | Web   : http://people.nscl.msu.edu/~priller/
East Lansing, MI 48824      |
Prev: Galil Motor Tutorial? Mark Clift
Next: Re: Device Support for I2C and GPIO Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Skip updating an output link in aSub ? Kasemir, Kay
Next: Re:problems solved about EPICS V4 4.5.0 compiling Qiao Yusi
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
