The driver is still under development. Documentation will be provided as soon as possible, yet more development is planned. I can help you with your project.
The controller you mention is a 1 axis controller, so I understand coordinated motion, and profile motion probably isn't in your interest area. Its easy to remove, and make it real simple.
A) The driver can connect to many controllers all at the same time. The example shows connection to a motor controller and RIO controller. You only have 1 controller. Proceed to comment one of them out, suggest the RIO. See point 2.
#Load kinematics for CS axis/motors (eg. Forward and reverse kinematics, kinematic variables)
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_csmotor_kinematics.substitutions")
#Load coordinate system features (eg. Coordinate system S and T status, motor list, segments processed, moving status)
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_coordinate_systems.substitutions")
#Load digital IO databases
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_digital_ports.substitutions")
#Load analog IO databases
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_analog_ports.substitutions")
#Load user defined functions
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_userdef_records.substitutions")
#Load profiles
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_profileMoveController.substitutions")
dbLoadTemplate("$(TOP)/GalilTestApp/Db/galil_profileMoveAxis.substitutions")
# Create a Galil controller
GalilCreateController("RIO", "192.168.0.51", 2)
# Start the controller
# Example using homing routine template assembly
#GalilStartController("Galil", "$(GALIL)/GalilSup/Db/galil_Default_Header.gmc;$(GALIL)/GalilSup/Db/galil_Home_RevLimit.gmc!$(GALIL)/GalilSup/Db/galil_Home_ForwLimit.gmc!$(GALIL)/GalilSup/Db/galil_Home_Home.gmc!$(GALIL)/GalilSup/Db/galil_Home_ForwLimit.gmc!$(GALIL)/GalilSup/Db/galil_Piezo_Home.gmc!$(GALIL)/GalilSup/Db/galil_Piezo_Home.gmc!$(GALIL)/GalilSup/Db/galil_Piezo_Home.gmc!$(GALIL)/GalilSup/Db/galil_Piezo_Home.gmc;$(GALIL)/GalilSup/Db/galil_Default_Footer.gmc",
0, 0, 3)
GalilStartController("RIO", "rio.gmc", 1, 0, 0)
# GalilCreateProfile command parameters are:
# 1. char *portName Asyn port for controller
# 2. Int maxPoints in trajectory
# Create trajectory profiles
GalilCreateProfile("Galil", 2000)
# Kinematics
# Forward transforms (Readbacks)
file "galil_forward_transform.req" P=$(P), M=I
file "galil_forward_transform.req" P=$(P), M=J
file "galil_forward_transform.req" P=$(P), M=K
file "galil_forward_transform.req" P=$(P), M=L
file "galil_forward_transform.req" P=$(P), M=M
file "galil_forward_transform.req" P=$(P), M=N
file "galil_forward_transform.req" P=$(P), M=O
file "galil_forward_transform.req" P=$(P), M=P
# Reverse transforms (Setpoints)
file "galil_reverse_transforms.req" P=$(P), M=I
file "galil_reverse_transforms.req" P=$(P), M=J
file "galil_reverse_transforms.req" P=$(P), M=K
file "galil_reverse_transforms.req" P=$(P), M=L
file "galil_reverse_transforms.req" P=$(P), M=M
file "galil_reverse_transforms.req" P=$(P), M=N
file "galil_reverse_transforms.req" P=$(P), M=O
file "galil_reverse_transforms.req" P=$(P), M=P
# Kinematic variables
file "galil_kinematic_variable.req" P=$(P), R=Q
file "galil_kinematic_variable.req" P=$(P), R=R
file "galil_kinematic_variable.req" P=$(P), R=S
file "galil_kinematic_variable.req" P=$(P), R=T
file "galil_kinematic_variable.req" P=$(P), R=U
file "galil_kinematic_variable.req" P=$(P), R=V
file "galil_kinematic_variable.req" P=$(P), R=W
file "galil_kinematic_variable.req" P=$(P), R=X
file "galil_kinematic_variable.req" P=$(P), R=Y
file "galil_kinematic_variable.req" P=$(P), R=Z
# First 16 Digital input bits
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi0
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi1
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi2
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi3
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi4
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi5
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi6
file "galil_digital_in_bit.req" P=$(P), R=Galil0Bi7
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi0
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi1
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi2
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi3
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi4
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi5
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi6
file "galil_digital_in_bit.req" P=$(P), R=Galil1Bi7
# First 16 Digital output bits
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo0
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo1
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo2
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo3
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo4
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo5
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo6
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo7
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo8
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo9
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo10
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo11
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo12
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo13
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo14
file "galil_digital_out_bit.req" P=$(P), R=Galil0Bo15
# First 8 Analog inputs
file "galil_analog_in.req" P=$(P), R=GalilAi0
file "galil_analog_in.req" P=$(P), R=GalilAi1
file "galil_analog_in.req" P=$(P), R=GalilAi2
file "galil_analog_in.req" P=$(P), R=GalilAi3
file "galil_analog_in.req" P=$(P), R=GalilAi4
file "galil_analog_in.req" P=$(P), R=GalilAi5
file "galil_analog_in.req" P=$(P), R=GalilAi6
file "galil_analog_in.req" P=$(P), R=GalilAi7
# First 8 Analog outputs
file "galil_analog_out.req" P=$(P), R=GalilAo0
file "galil_analog_out.req" P=$(P), R=GalilAo1
file "galil_analog_out.req" P=$(P), R=GalilAo2
file "galil_analog_out.req" P=$(P), R=GalilAo3
file "galil_analog_out.req" P=$(P), R=GalilAo4
file "galil_analog_out.req" P=$(P), R=GalilAo5
file "galil_analog_out.req" P=$(P), R=GalilAo6
file "galil_analog_out.req" P=$(P), R=GalilAo7
Motor extras database is critical and cannot be removed, else lose above settings! If script must provide these settings then use autosave file format.
I'm happy to help further. Good luck, and best wishes.
