1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Issues with building EDM on Debian 8 32bit
To: Shawn Rapaz <[email protected]>, [email protected]
Date: Wed, 13 Jan 2016 22:34:23 -0500
> EPICS_BASE=/usr1/local/epics/release/R3.14.12.5/base
> -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux
-I../../../../include/edm -I../../util -I../../lib
> -I/lib/i386-linux-gnu -I/usr/lib/i386-linux-gnu
I'm puzzled that I don't see the path to EPICS Base here.  Specifically
you should see "-I$(EPICS_BASE) -I$(EPICS_BASE)/os/Linux" (expanded of
course).
However, the fast that make proceeds far enough to invoke the compiler
suggests that you have the correct path for EPICS_BASE.
> ../group.h:27:21: fatal error: cvtFast.h: No such file or directory
"cvtFast.h" comes from EPICS Base.  Does it exist for you as
"/usr1/local/epics/release/R3.14.12.5/base/include/cvtFast.h"?  If not
then Base is probably not build correctly.
FYI, a set of instructions which I've checked
http://mdavidsaver.github.io/epics-doc/epics-starting.html
On 01/13/2016 04:56 PM, Shawn Rapaz wrote:
> Hello,
> I have successfully built EPICS Base as well as EPICS extensions but I
> cannot build EDM successfully. I am currently trying to build
> edm-1-12-102. I have the following set:
> /usr1/local/epics/extensions/configure/RELEASE:
> EPICS_EXTENSIONS=$(TOP)
> OAG_APPS=$(TOP)/../../oag/apps
> /usr1/local/epics/extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86:
> X11_LIB=/lib/i386-linux-gnu
> X11_INC=/usr/lib/i386-linux-gnu
> MOTIF_LIB=/usr/lib/i386-linux-gnu
> MOTIF_INC=/lib/i386-linux-gnu
> I also created a /usr/X11R6 directory with the following link:
>  lib -> /lib/i386-linux-gnu
> This is my export:
> export EPICS_HOST_ARCH=linux-x86
> When I try to build, I get the following error:
> /usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_
> -DUNIX  -Dlinux     -O3 -g   -Wall     -DSINGLE_THREADED=1
> -D__epics__=1   -m32     -fPIC -MMD -I. -I../O.Common -I. -I..
> -I../../../../include/edm/os/Linux -I../../../../include/edm
> -I../../util -I../../lib -I/lib/i386-linux-gnu
> -I/usr/lib/i386-linux-gnu    ../app_pkg.cc
> In file included from ../bindings.h:27:0,
>                  from ../act_win.h:44,
>                  from ../app_pkg.h:36,
>                  from ../app_pkg.cc:19:
>  #include "cvtFast.h"
> compilation terminated.
> ../../../../configure/RULES_BUILD:213: recipe for target 'app_pkg.o'
> failed
> make[2]: *** [app_pkg.o] Error 1
> make[2]: Leaving directory
> '/usr1/local/epics/extensions/src/edm-1-12-102/lib/O.linux-x86'
> ../../../configure/RULES_ARCHS:64: recipe for target
> 'install.linux-x86' failed
> make[1]: *** [install.linux-x86] Error 2
> make[1]: Leaving directory
> '/usr1/local/epics/extensions/src/edm-1-12-102/lib'
> ../../configure/RULES_DIRS:87: recipe for target 'lib.install' failed
> make: *** [lib.install] Error 2
> Any advice or help would be much appreciated. Thank you in advance.
> Shawn Rapaz
Re: Issues with building EDM on Debian 8 32bit Shawn Rapaz
Prev: Re:problems solved about EPICS V4 4.5.0 compiling Qiao Yusi
Next: Re: Skip updating an output link in aSub ? Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Issues with building EDM on Debian 8 32bit Shawn Rapaz
Next: Re: Issues with building EDM on Debian 8 32bit Shawn Rapaz
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
