1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cost effective solution for monitor a large number of temperatures w EPICS
To: Ryan Pierce <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 13 Jan 2016 08:25:37 +0100
Ryan,
I'm looking to find something that works out of the box. The PT100 is a requirements.
Beckhoff has a KL320X, I thought someone has experienced on that...
I've to balance the cost and the reliability of this solution.
Thansk,
-Mauro
On 1/12/2016 5:16 PM, Ryan Pierce wrote:
Does "cost effective solution" apply to parts only or include labor? Are you willing to build your own solution, or are you looking for something that works out of the box? If the former:
I've worked with voltage-based analog temperature sensors (TMP36) before. In that case, I designed a Raspberry Pi shield board that included an 8-channel 10-bit ADC addressable via SPI. See http://www.mackenziegems.com/2013/03/14/chillmon-board/ I imagine you could do the same thing with resistance-based PT100's if you set up a voltage divider for each input. The board fabrication and component price was $22 for 8 channels, although you'd need to add in a Raspberry Pi, SD card, power supply, etc. For your application, I might consider dispensing with the Pi altogether, making a shield board for an AVR microcontroller, and have that communicate the channel data with an IOC via USB or TTL serial. I'm amazed at how small, inexpensive, and powerful these AVRs have become, in particular the Teensy: https://www.pjrc.com/teensy/
Does it have to be PT100? I strongly prefer digital sensors if possible. I'm currently using DS18B20 OneWire temperature sensors for my brewing project. They are individually addressable and can be strung together in a bus. Resolution is 1/16 degree C if you're willing to wait 750 ms for a conversion; you can configure them to use lower precision which will reduce the conversion time. I don't know how far these 100 sensors are spaced out; you may run into bus length limitations with OneWire, but I've seen documents that talk about improving OneWire performance for long or noisy buses. I'm using an AVR microcontroller to bit bang the OneWire bus, and this is queried via USB serial. OneWire has the ability to detect a broken bus, a non-reporting device, or a transmission error via a CRC. The AVR can check this and raise an EPICS alarm if the output becomes invalid. You could also use one microcontroller to run several independent OneWire buses. This approach is likewise very inexpensive.
Ryan
________________________________________________________________________
Mauro Giacchini
Control Systems Specialist
INFN Laboratori Nazionali di Legnaro
Viale Università 2
I 35020 Legnaro (Padova)
Tel. +39 049 8068 558
Fax               558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
RE: Cost effective solution for monitor a large number of temperatures w EPICS ronaldo.mercado
Cost effective solution for monitor a large number of temperatures w EPICS Jack
Re: Cost effective solution for monitor a large number of temperatures w EPICS Ryan Pierce
Prev: RE: Device Support for I2C and GPIO Mark Rivers
Next: RE: Cost effective solution for monitor a large number of temperatures w EPICS ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Cost effective solution for monitor a large number of temperatures w EPICS Phil Atkin
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
