1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: terminal server/serial server/console management switch recommendations?
To: Maren Purves <[email protected]>, EPICS tech-talk <[email protected]>
Date: Sat, 9 Jan 2016 00:44:30 -0600
Back when I had a rack full of networking gear that I needed to manage via serial interfaces, I put a Stallion multi-port RS-232 card in a Linux box. It had good kernel support, and each port appeared as its own tty device. Then I could ssh to the box and access each port via minicom.
I suppose you could likewise use a Stallion card in a Linux box that runs an IOC to control serial devices using asyn.
It's been a while since I've used these. I'm seeing old hardware on eBay. I don't suppose they make more modern multi-port serial devices for PCs that have Linux support?
Cheers,
Ryan
terminal server/serial server/console management switch recommendations? Maren Purves
Prev: RE: terminal server/serial server/console management switch recommendations? Mark Rivers
Next: problems about EPICS V4 4.5.0 compiling Qiao Yusi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: RE: terminal server/serial server/console management switch recommendations? Mazanec Tomáš
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
