To complete the documentation around this topic:
There are some some cases/people/projects/sites that want to flag
loading duplicate records as an error. For them, there is a control
variable that can be set to make dbLoadRecords() print an error message
if a record already exists with the same name (available in all Base
releases back to 3.14.8). From the iocsh the command to set that is
var dbRecordsOnceOnly 1
or from the VxWorks shell
dbRecordsOnceOnly=1
- Andrew
On 01/08/2016 08:18 AM, Kasemir, Kay wrote:
> Hi:
> Loading several *.db files can be a very useful approach.
> Typically you first load *.db files that define all the records, then later load additional *.db files which add fields to those records.
> Loading more *.db files that modify fields that were already defined can be a bit confusing to maintain in the long run, but adding fields is often a good idea.
> For example, the original *.db files can define the logic, and later you load *.db files that set ASG.
> For this to “work”, the record type must remain the same, unless you have a very new release of EPICS base.
> From the 3.15.0.2 release notes:
> Database field setting updates
> A database (.db) file loaded by an IOC does not have to repeat the record type of a record that has already been loaded. It may replace the first parameter of the record(type, name) statement with an asterisk character inside double-quotes, "*" instead. Thus the following is a legal database file:
> record(ao, "ao1") {}
> record("*", "ao1") {
> field(VAL, 10)
> The “*” for a type was specifically supported to allow
> record(ao, “some_record)
> logic-related fields ..
> Then another *.db file:
> # Don’t care about the record type, just want to configure access security:
> record(“*", “some_record)
> field(ASG, “SPECIAL”)
> -Kay
>>> On Fri, Jan 8, 2016 at 7:40 AM, <[email protected]> wrote:
>>> I have implemented a record in two separate files which I then use substitutions to combine into a single db file. I am unsure I am allowed to do this after talking to a colleague; he is worried that this will create 2 PVs with identical names. My DB file contains (after make):
>>> record(ai, "NAME") {
>>> field(DESC, "A PV")
>>> field(EGU, "Gauss")
>>> field(FLNK, "ANOTHER_RECORD")
>>> Does this do what I am expecting, which is to create a single PV:
>>> field(DESC, "A PV")
>>> field(EGU, "Gauss")
>>> Thank you.
>>> John
There are only two hard problems in distributed systems: 2. Exactly-once
delivery 1. Guaranteed order of messages 2. Exactly-once delivery
-- Mathias Verraes
- Can I override record definition twice in an IOC John . Holt
- Re: Can I override record definition twice in an IOC bob dalesio
- Re: Can I override record definition twice in an IOC Ralph Lange
- Re: Can I override record definition twice in an IOC Kasemir, Kay
Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
<2016>
terminal server/serial server/console management switch recommendations? Maren Purves
<2016>
