If you are loading multiple instances of the same record into the same IOC, the second one will just overwrite the fields that were defined in the first one to be loaded, with those that are defined in the second instance. On Fri, Jan 8, 2016 at 7:40 AM, <[email protected]> wrote: I have implemented a record in two separate files which I then use substitutions to combine into a single db file. I am unsure I am allowed to do this after talking to a colleague; he is worried that this will create 2 PVs with identical names. My DB file contains (after make):
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
