1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Fwd: Re: mrfioc2 loading error at vxWorks 6.9
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 7 Jan 2016 13:32:56 -0500
forgot to cc the list
-------- Forwarded Message --------
Subject: Re: mrfioc2 loading error at vxWorks 6.9
Date: Thu, 7 Jan 2016 12:50:04 -0500
To: Andrew Johnson <[email protected]>, 김지화(빔라인장치팀) <[email protected]>, Konrad, Martin <[email protected]>
CC: [email protected] <[email protected]>
On 01/07/2016 12:41 PM, Andrew Johnson wrote:
> The C++ 'extern "C" {}' wrapper around those declarations is needed in
> the epicsMMIO.h file in Base, not (just?) in devlib2.
When devlib2 is built against Base <3.15.1 the copy of epicsMMIO.h in
devlib2 is installed.  When built against >=3.15.1 the copy in Base is used.
For completeness both copies should be patched.
Prev: Re: areaDetector driver pixel types Phil Atkin
Next: RE: areaDetector driver pixel types Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: mrfioc2 loading error at vxWorks 6.9 Konrad, Martin
Next: Re: mrfioc2 loading error at vxWorks 6.9 Andrew Johnson
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
