Hello. i'm in trouble with Nozzle Exchange Device..------------------------------- ---------------------------------- @writetimeout { disconnect; } @replytimeout { disconnect; } @readtimeout { disconnect; } @mismatch { disconnect; } ReplyTimeout = 1200; #InTerminator = 92 114 92 110; InTerminator = "\r\n"; OutTerminator = "\r\n"; #OutTerminator = 92 114 92 110; # # Measure current # GetRemoteSta { out "!50SWS"; #out 33 53 48 83 87 83 92 114; #out 33 53 48 83 87 83 67 114; in "?50%1d"; #in 63 53 48 37 49 100 92 114; ExtraInput = Ignore; } -------------------------------------------- ------------------------------------ # # Reading # record(bi, "$(P)$(D):GetRemoteSta") { field(DESC, "Local/Remote Status") field(DTYP, "stream") field(INP, "@devNozzleExchange.proto GetRemoteSta $(PORT) $(A)") field(ZNAM, "Local") field(ONAM, "Remote") field(SCAN, ".2 second") field(FLNK, "$(P)$(D):GetCryoSolSta") } ----------------------------------------- ------------------------------------------- 2015/12/28 21:38:31.714 192.100.100.20:4009 write 8 !50SWS\r\n 2015/12/28 21:38:31.915 192.100.100.20:4009 read 6 ER=1\r\n 2015/12/28 21:38:31.915 MX1_9 BL5C:NOZZLE:GetRemoteSta: Input "ER=1" mismatch after 0 bytes 2015/12/28 21:38:31.916 MX1_9 BL5C:NOZZLE:GetRemoteSta: got "ER=1" where "?50" was expected ---------------------------------------- ------------------------------ ------------------------------------------------------ i want to send ascii code(convert out "!50SWS" to ascii code) how can i do it? is it .proto function? is it another solution?
ANJ, 28 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
