Re: Problem: nozzle exchanger Local/Remote pv value is not received (???)Thank for your help but i don't know How to detect some problem.... How can i see the problem with communication with the device if these text are added, where can i see? 2, 9 number what is mean? >You should enable asynTrace on the $(PORT) and $(A) to see what is actually happening with communication with the device. >asynSetTraceIOMask($(PORT), $(A), 2) >asynSetTraceMask($(PORT), $(A), 9) >Mark ---------- Forwarded message ---------- From: <[email protected]> Date: 2015-12-25 3:00 GMT+09:00 Subject: Tech-talk Digest, Vol 9, Issue 397 To: [email protected] Send Tech-talk mailing list submissions to [email protected] To subscribe or unsubscribe via the World Wide Web, visit https://mailman.aps.anl.gov/mailman/listinfo/tech-talk or, via email, send a message with subject or body 'help' to [email protected] You can reach the person managing the list at [email protected] When replying, please edit your Subject line so it is more specific than "Re: Contents of Tech-talk digest..." Today's Topics: 1. Re: EPICS synApps installation ERROR. Please, Help me. (Pete Jemian) 2. Re: EPICS synApps installation ERROR. Please, Help me. (Mark Engbretson) 3. Problem: nozzle exchanger Local/Remote pv value is not received (???) 4. Re: Problem: nozzle exchanger Local/Remote pv value is not received (Mark Rivers) 5. APS Shutdown and Network Maintenance (Johnson, Andrew N.) ---------------------------------------------------------------------- Message: 1 Date: Wed, 23 Dec 2015 12:00:21 -0600 From: Pete Jemian <[email protected]> To: <[email protected]> Subject: Re: EPICS synApps installation ERROR. Please, Help me. Message-ID: <[email protected]" target="_blank">[email protected]> Content-Type: text/plain; charset="utf-8"; format=flowed The synApps has a different build structure than the EPICS extensions. If synApps is installed in the extensions/src directory, it is not likely to be built at all. The README file at the base of the synApps directory structure (https://github.com/EPICS-synApps/support/blob/master/README) has build instructions. Which synApps version are you installing? Did you get it from a .tar.gz file or from a source code repository? Can you send the complete output from your gmake command? Pete On 12/22/2015 8:06 PM, [email protected] wrote: > hello. > > Pleas, Help me. > > I have some questions about EPICS installation. > > I use "fedora 20" with "Cinnamon desktop". User name is "cha" > > I installed the synApp in extensions directory and everything is fine > (no any error come out from gmake). > > But when i check the file in extensions directory, The gmake did not > build the "lib" directory. > > I am not sure why is happened, If you a a time and have some > suggestions please would you let me know??? > > The extensions folder contains: bin, configure, html, Makefile, README, > and src > But, no have "lib". > > I totally 10 time format and install again. again again. > > what's problems? please, help me > > Thanks. > > Cha > -- ---------------------------------------------------------- Pete R. Jemian, Ph.D. <[email protected]> Beam line Controls and Data Acquisition, Group Leader Advanced Photon Source, Argonne National Laboratory Argonne, IL 60439 630 - 252 - 3189 ----------------------------------------------------------- Education is the one thing for which people are willing to pay yet not receive. ----------------------------------------------------------- ------------------------------ Message: 2 Date: Wed, 23 Dec 2015 14:41:33 -0600 From: Mark Engbretson <[email protected]> To: Pete Jemian <[email protected]> Cc: [email protected] Subject: Re: EPICS synApps installation ERROR. Please, Help me. Message-ID: <[email protected]" target="_blank">[email protected]> Content-Type: text/plain; charset=us-ascii Synapps is also NOT a single product. It is a grouping of different modules so any bin and lib files would be under the actual product directory, not in any sort of master bin, include, or lib files. This is because versions of everything change a lot, so would be harder to know exactly what you are building against if you had multiple versions. On Dec 23, 2015, at 12:00, Pete Jemian <[email protected]> wrote: The synApps has a different build structure than the EPICS extensions. If synApps is installed in the extensions/src directory, it is not likely to be built at all. The README file at the base of the synApps directory structure (https://github.com/EPICS-synApps/support/blob/master/README) has build instructions. Which synApps version are you installing? Did you get it from a .tar.gz file or from a source code repository? Can you send the complete output from your gmake command? Pete > On 12/22/2015 8:06 PM, [email protected] wrote: > hello. > > Pleas, Help me. > > I have some questions about EPICS installation. > > I use "fedora 20" with "Cinnamon desktop". User name is "cha" > > I installed the synApp in extensions directory and everything is fine > (no any error come out from gmake). > > But when i check the file in extensions directory, The gmake did not > build the "lib" directory. > > I am not sure why is happened, If you a a time and have some > suggestions please would you let me know??? > > The extensions folder contains: bin, configure, html, Makefile, README, > and src > But, no have "lib". > > I totally 10 time format and install again. again again. > > what's problems? please, help me > > Thanks. > > Cha -- ---------------------------------------------------------- Pete R. Jemian, Ph.D. <[email protected]> Beam line Controls and Data Acquisition, Group Leader Advanced Photon Source, Argonne National Laboratory Argonne, IL 60439 630 - 252 - 3189 ----------------------------------------------------------- Education is the one thing for which people are willing to pay yet not receive. ----------------------------------------------------------- ------------------------------ Message: 3 Date: Thu, 24 Dec 2015 14:14:27 +0900 (KST) From: ??? <[email protected]> To: [email protected] Subject: Problem: nozzle exchanger Local/Remote pv value is not received Message-ID: <[email protected]" target="_blank">[email protected]> Content-Type: text/plain; charset="utf-8" Hello.. i'm reparing the ioc of Nozzle Exchanger. Now, pv value (Local/Remote) is viewing in medm... but this is decoy... i think it is default value. when i switch Remote/Local S/W in Nozzle Exchanger, pv value in medm is not changed. this pv value is a valuable data? i know "st.cmd" deamon is ioc deamon. so i stoped "st.cmd" deamon. and i see all of pv value in medm is blanked. and i started "st.cmd" so, i see all of py value is displayed (but these value is not correct) and i updated .db of device and i restart ioc deamon i add the pv object in medm. and i see the default value of added pv in medm is this situation correct? somthing is missed.. ----------------------------------------------------------------- devNozzleExchange.db ------------------------------------------------------------------- record(bi, "$(P)$(D):GetRemoteSta") { field(DESC, "Local/Remote Status") field(DTYP, "stream") field(INP, "@devNozzleExchange.proto GetRemoteSta $(PORT) $(A)") field(ZNAM, "Local") field(ONAM, "Remote") field(SCAN, ".2 second") field(FLNK, "$(P)$(D):GetCryoSolSta") } ... ----------------------------------------------------------------------- ----------------------------------------------------------------------- devNozzleExchage.proto ----------------------------------------------------------------------- @writetimeout { disconnect; } @replytimeout { disconnect; } @readtimeout { disconnect; } @mismatch { disconnect; } ReplyTimeout = 1200; InTerminator = "\r\n"; OutTerminator = "\r\n"; # # Measure current # GetRemoteSta { out "!50SWS"; in "?50%1d"; ExtraInput = Ignore; } GetCryoSolSta { out "!51SOL"; in "?51%1d%*2d"; ExtraInput = Ignore; } .....-----------------------------------------------------------------------------this is code... ??????? -------------- next part -------------- An HTML attachment was scrubbed... URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20151224/e72423b4/attachment.html> ------------------------------ Message: 4 Date: Thu, 24 Dec 2015 15:06:15 +0000 From: Mark Rivers <[email protected]> To: ??? <[email protected]> Cc: "[email protected]" <[email protected]> Subject: Re: Problem: nozzle exchanger Local/Remote pv value is not received Message-ID: <[email protected]" target="_blank">[email protected]> Content-Type: text/plain; charset="ks_c_5601-1987" You should enable asynTrace on the $(PORT) and $(A) to see what is actually happening with communication with the device. asynSetTraceIOMask($(PORT), $(A), 2) asynSetTraceMask($(PORT), $(A), 9) Mark Sent from my iPhone On Dec 24, 2015, at 3:13 AM, ??? <[email protected]<mailto:[email protected]>> wrote: Hello.. i'm reparing the ioc of Nozzle Exchanger. Now, pv value (Local/Remote) is viewing in medm... but this is decoy... i think it is default value. when i switch Remote/Local S/W in Nozzle Exchanger, pv value in medm is not changed. this pv value is a valuable data? i know "st.cmd" deamon is ioc deamon. so i stoped "st.cmd" deamon. and i see all of pv value in medm is blanked. and i started "st.cmd" so, i see all of py value is displayed (but these value is not correct) and i updated .db of device and i restart ioc deamon i add the pv object in medm. and i see the default value of added pv in medm is this situation correct? somthing is missed.. ----------------------------------------------------------------- devNozzleExchange.db ------------------------------------------------------------------- record(bi, "$(P)$(D):GetRemoteSta") { field(DESC, "Local/Remote Status") field(DTYP, "stream") field(INP, "@devNozzleExchange.proto GetRemoteSta $(PORT) $(A)") field(ZNAM, "Local") field(ONAM, "Remote") field(SCAN, ".2 second") field(FLNK, "$(P)$(D):GetCryoSolSta") } ... ----------------------------------------------------------------------- ----------------------------------------------------------------------- devNozzleExchage.proto ----------------------------------------------------------------------- @writetimeout { disconnect; } @replytimeout { disconnect; } @readtimeout { disconnect; } @mismatch { disconnect; } ReplyTimeout = 1200; InTerminator = "\r\n"; OutTerminator = "\r\n"; # # Measure current # GetRemoteSta { out "!50SWS"; in "?50%1d"; ExtraInput = Ignore; } GetCryoSolSta { out "!51SOL"; in "?51%1d%*2d"; ExtraInput = Ignore; } ..... ----------------------------------------------------------------------------- this is code... ????? [???]<http://blog.naver.com/pmjzzang78.do> ??<http://blog.naver.com/pmjzzang78.do> <http://blog.naver.com/pmjzzang78.do> [http://mail.naver.com/readReceipt/notify/?img=bdRCDNG8WBgZhAn%2FFr%2B5FzJSM4K9MouXFzuZKrpCKqgwFzkvKxi4p6FCazEdpvIo%2BrkSKoU5W4d5W4C5bX0q%2BzkR74FTWx%2Fs%2Bzko1V9dM6wOtzJmbZlCW4m5prer.gif] ----------------------------------------------------------------------------- ------------------------------ Message: 5 Date: Thu, 24 Dec 2015 16:49:38 +0000 From: "Johnson, Andrew N." <[email protected]> To: "[email protected]" <[email protected]> Subject: APS Shutdown and Network Maintenance Message-ID: <[email protected]" target="_blank">[email protected]> Content-Type: text/plain; charset="us-ascii" Users of tech-talk and the EPICS website are warned that this mailing list and the website are likely to be affected by the maintenance work that our IT group will be performing on the APS network and servers over the next week or two after Christmas. Email sent to tech-talk while the servers are down should be queued up for eventual delivery, so please don't re-send any messages that don't appear to get through unless you get a final notice from the postmaster that your message cannot be delivered. Things should be mostly back to normal by January 4th when Argonne re-opens, although short-term outages could still occur after that date. Wishing everyone an enjoyable holiday season. - Andrew -- Sent from my iPad ------------------------------ _______________________________________________ Tech-talk mailing list [email protected] https://mailman.aps.anl.gov/mailman/listinfo/tech-talk End of Tech-talk Digest, Vol 9, Issue 397 *****************************************
ANJ, 27 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
