The SNS Beam Instrumentation group has been using LabVIEW/EPICS
systems for several devices in the accelerator. There are more than
300 devices being controlled by Windows based PCs running LabVIEW.
These include: Beam Current Monitors, Beam Position Monitors, Wire
Scanners and more...
A majority of the LabVIEW systems are using a Shared Memory
Interface with EPICS. This is a windows based system that runs a
EPICS IOC shell along side the LabVIEW to propagate records on the
controls network.
"Options for Interfacing EPICS to COTS Hardware Through LabView"
http://epaper.kek.jp/icalepcs2009/papers/thd004.pdf
"A Shared Memory Interface Between LabVIEW and EPICS"
https://accelconf.web.cern.ch/accelconf/ica03/PAPERS/TU514.PDF
"Network Attached Devices"
http://citeseerx.ist.psu.edu/viewdoc/download;jsessionid=C395D88BC6386FCE86639ADAAF090CC1?doi=10.1.1.130.5186&rep=rep1&type=pdf
Pros:
- As Network Attached Devices, instruments can be easily added or
removed from system.
- Can use cheaper components not VME based...
Cons:
- LabView process can die without EPICS IOC shell being aware. Issue
can possibly be resolved using a watchdog signal.
There is an another implementation that uses a LabVIEW native
channel access server that will work on all platforms.
"Pure LabVIEW Implementation of EPICS Communication Protocol"
https://wiki.gsi.de/foswiki/pub/Epics/ConnectingLabVIEWandEPICS/PureLabVIEWImplementationofEPICSCommunicationProtocol-Zhukov.pdf
A new control system for high voltage converter modulators using
LabVIEW and National Instruments PXIe Flex-RIO FPGA's and custom
analog and digital interface hardware is using this version of
LabVIEW/EPICS.
Pros:
- Can run on any LABVIEW platform
Cons:
- Channel access security is not fully implemented in this system.
- EPICS PV fields only exist if developer creates them. One can have
a process with .VAL field and no other field set. This makes
interfacing with archive and alarm servers difficult.
Tim
On 12/17/15 2:50 PM, Wyman, Max D
wrote:
Hello,
I’m
investigating the pro’s/con’s of a hybrid LabVIEW/EPICS system
for the control and DAQ on PRIME Lab’s accelerator. We’ll be
adding a second ion source (and requisite controllers) so it
seems like a good time to make such a migration if it seems
beneficial. Currently we use a suite of LabVIEW applications
for control/DAQ of a dozen NI cRIOs, a handful of NI
GPIB-ethernet controllers, and two NI PXI chassis as our
input/output controllers.
In
particular, I’m curious to talk to anybody who’s ever migrated a
system from pure LabVIEW to a LabVIEW/EPICS hybrid or who
currently runs an EPICS system involving controllers similar to
ours (the NI cRIOs, PXI crates, and GPIB-ENET controllers).
Max
Max Wyman
PRIME Lab, Purdue University
765-496-6894
- Pro's/Con's of LabVIEW/EPICS Wyman, Max D
Is there any demo or doc of the VTable Display in CCS? WangWill
RE: Pro's/Con's of LabVIEW/EPICS Mazanec Tomáš
<2015>
Re: Pro's/Con's of LabVIEW/EPICS Paul Sichta
<2015>
ANJ, 22 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
