Hello Max,
The one point that always annoyed me with LabVIEW/EPICS integrations is
the lack of error propagation. While both, LabVIEW and EPICS have their
own sophisticated system to propagate errors between records and VIs
respectively, usually only the value is passed between the two worlds.
I examined in particular the cRIO implementation of running EPICS and
LabView side by side on the same system. Data passing is done with a
shared memory region which is accessed by both sides with their own scan
rates. Unfortunately there is no synchronization mechanism which would
allow to trigger one side when the other one has new values. There is no
space for error states, no space for time stamps. Only data. All of this
would have been straight forward to implement. All the necessary API
functionality is there. It has just not been done.
Looking into the details of the "EPICS-VI" implementation reviles that
the VI handles error input, but in an inadequate way: Instead of passing
the error, it simply skips to copy new (invalid) data to the shared
memory. Thus when a device breaks, EPICS will happily read the last good
value. And EPICS will put a current time stamp on the old data. Thus
there is no way to see the problem in EPICS.
It has been a few years that I looked at this solution. So it may be
that the situation has improved meanwhile. But I was so disappointed
that I lost any interest.
Dirk
On 17.12.2015 20:50, Wyman, Max D wrote:
Hello,
I’m investigating the pro’s/con’s of a hybrid LabVIEW/EPICS system for
the control and DAQ on PRIME Lab’s accelerator. We’ll be adding a second
ion source (and requisite controllers) so it seems like a good time to
make such a migration if it seems beneficial. Currently we use a suite
of LabVIEW applications for control/DAQ of a dozen NI cRIOs, a handful
of NI GPIB-ethernet controllers, and two NI PXI chassis as our
input/output controllers.
In particular, I’m curious to talk to anybody who’s ever migrated a
system from pure LabVIEW to a LabVIEW/EPICS hybrid or who currently runs
an EPICS system involving controllers similar to ours (the NI cRIOs, PXI
crates, and GPIB-ENET controllers).
Max
Max Wyman
PRIME Lab, Purdue University
[email protected] <mailto:[email protected]>
765-496-6894
- Re: Pro's/Con's of LabVIEW/EPICS David Vine
- Pro's/Con's of LabVIEW/EPICS Wyman, Max D
RE: Pro's/Con's of LabVIEW/EPICS freddie.akeroyd
<2015>
<2015>
ANJ, 18 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
