On 16/12/15 16:39, Phil Atkin wrote:
Hi folks,
My plugin needs to build and output a very large image - 1GB would
not be surprising. The contents of the image are gradually
accumulated as many images are produced by the detector driver.
I'm not sure how I can make this 'fit' the NDArray/NDArrayPool
architecture. If I make the accumulator image a private area of
memory then I could copy to an output NDArray when required - but
that requires even more memory.
My ideal approach would be for my plugin to allocate the
accumulator array (a 'worker' class currently encapsulates this),
and only when the output is required would a pointer to this
memory be used to 'publish' the result through an NDArray.
If I created a private NDArray and set its pData pointer to my
accumulator image, could I then pass this to
doCallbacksGenericPointer instead of the usual
this->pArrays[0]? If so, that call would presumably be
inexpensive unless/until a client subscribed to the output port?
Why not allocate an NDArray large enough to fit the whole image and
write straight to it?
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
Kingdom
- areaDetector plugin: very large output array Phil Atkin
RE: areaDetector plugin: very large output array Mark Rivers
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
