Hi Adeel,
Did you following the Ubuntu instructions given at the bottom of the
MEDM page at http://www.aps.anl.gov/epics/extensions/medm/index.php ?
If the list of Ubuntu packages needed has changed from the ones listed
there please let me know what else you have to install.
- Andrew
On 12/14/2015 11:34 AM, Adeel Akram wrote:
> Hello Guys,
> I am new to EPICS. I am using EPICS base-3.15.3. I am using Ubuntu 15.10
> 64bit as test OS (I also need to install it on Debian 8.1 later on,
> which is my server). Following is my epics installation directory structure
> ~/epics/base (successfully build)
> ~/epics/extensions
> I am trying to install medm3.1.9 extension. After running
> "adeel@ubuntu1510:~/epics/extensions/src/medm$ make" , I am getting
> following errors (after some compiling)
> ../xgif.c:156:9: warning: variable ‘x’ set but not used
> [-Wunused-but-set-variable]
> int x, y;
> make[2]: *** No rule to make target '/usr/lib64/libXm.a', needed by
> 'medm'. Stop.
> make[2]: Leaving directory
> '/home/adeel/epics/extensions/src/medm/medm/O.linux-x86_64'
> ../../../../base/configure/RULES_ARCHS:64: recipe for target
> 'install.linux-x86_64' failed
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory '/home/adeel/epics/extensions/src/medm/medm'
> ../../../base/configure/RULES_DIRS:87: recipe for target 'medm.install'
> failed
> make: *** [medm.install] Error 2
> It seems the problem is with libXm.a which is part of libxp-dev and its
> not available on Ubuntu 15.10. I downloaded libxp-dev from launchpad but
> it need libxp6 which is also not available on ubuntu. I searched on
> tech-talk but I couldn't find the satisfactory solution. I will
> appreciate your expert help. Please link if solution is already given
> (may be I could not get it).
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- MEDM Extension Make Failed on Ubuntu 15.10 Adeel Akram
Re: Newbie: How do I view the output of an areaDetector plugin? Andrew Johnson
RE: Newbie: How do I view the output of an areaDetector plugin? Mark Rivers
<2015>
RE: MEDM Extension Make Failed on Ubuntu 15.10 Mark Rivers
Re: MEDM Extension Make Failed on Ubuntu 15.10 Jeong Han Lee
<2015>
