1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MEDM Extension Make Failed on Ubuntu 15.10
To: Adeel Akram <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 14 Dec 2015 17:47:54 +0000
The library you need is Motif.  It looks like there is at least a source code version for Ubuntu 15 here:
https://launchpad.net/ubuntu/vivid/+source/motif
I am not an Ubuntu user, but you might want to see if you can find a binary package to install called libmotif-dev or something similar.
From: [email protected] [[email protected]] on behalf of Adeel Akram [[email protected]]
Sent: Monday, December 14, 2015 11:34 AM
To: [email protected]
Subject: MEDM Extension Make Failed on Ubuntu 15.10
Hello Guys,
I am new to EPICS. I am using EPICS base-3.15.3. I am using Ubuntu 15.10
64bit as test OS (I also need to install it on Debian 8.1 later on,
which is my server). Following is my epics installation directory structure
~/epics/base (successfully build)
~/epics/extensions
I am trying to install medm3.1.9 extension. After running
"adeel@ubuntu1510:~/epics/extensions/src/medm$ make" , I am getting
following errors (after some compiling)
../xgif.c:156:9: warning: variable ‘x’ set but not used
[-Wunused-but-set-variable]
      int x, y;
make[2]: *** No rule to make target '/usr/lib64/libXm.a', needed by
'medm'.  Stop.
make[2]: Leaving directory
'/home/adeel/epics/extensions/src/medm/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:64: recipe for target
'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/adeel/epics/extensions/src/medm/medm'
../../../base/configure/RULES_DIRS:87: recipe for target 'medm.install'
failed
make: *** [medm.install] Error 2
It seems the problem is with libXm.a which is part of libxp-dev and its
not available on Ubuntu 15.10. I downloaded libxp-dev from launchpad but
it need libxp6 which is also not available on ubuntu. I searched on
tech-talk but I couldn't find the satisfactory solution. I will
appreciate your expert help. Please link if solution is already given
(may be I could not get it).
Best,
Adeel Akram
Universität Heidelberg.
MEDM Extension Make Failed on Ubuntu 15.10 Adeel Akram
Prev: Newbie: How do I view the output of an areaDetector plugin? Phil Atkin
Next: areaDetector: plugin in separate dll Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: MEDM Extension Make Failed on Ubuntu 15.10 Adeel Akram
Next: Re: MEDM Extension Make Failed on Ubuntu 15.10 Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
