1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem compiling Base after linux distribution upgrade
To: Michael Westfall <[email protected]>
Cc: <[email protected]>
Date: Fri, 11 Dec 2015 18:30:48 +0200
Michael Westfall <[email protected]> writes:
> '/opt/epics/base-3.14.12.4/src/cap5/O.linux-x86_64'
> make[3]: *** No rule to make target '/usr/lib/perl/5.14/CORE/EXTERN.h',
> needed by 'Cap5.o'.  Stop.
This means that the file doesn't exists. That file was part of
perl-package in wheezy.
With jessie, it should be /usr/lib/x86_64-linux-gnu/perl/5.20.2/CORE/EXTERN.h
> Seems I'm lacking some perl stuff.
> I tried 'sudo apt-get install libperl-dev', and it downloaded and
> installed,
> but I still have the same error.
> What am I forgetting to install?
"make clean" might help or starting with base-3.14.12.4 directory
unpacked from the source archive i.e. no prior compilation in that
directory.
Jani Hakala
Problem compiling Base after linux distribution upgrade Michael Westfall
Prev: Problem compiling Base after linux distribution upgrade Michael Westfall
Next: Re: Problem compiling Base after linux distribution upgrade Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
