What is wrong:
FLNK does not pass any data. You need an OUT link to pass data. ai does
not have an OUT link. You need ao to do that. ao does not have an INP
link. Use DOL the link. To read the DOL you must set OMSL to
closed_loop. Make all the OUT links PP to process the offset record.
record(ao, "$(dev):calcoffset") {
field(DTYP, "Soft Channel")
field(OMSL, "closed_loop")
field(DOL, "$(dev):rawval")
field(OUT, "$(dev):offset PP")
record(ai, "$(dev):offset") {
record(ao, "$(dev):zeroOffset") {
field(VAL, "0")
On 11.12.2015 10:16, Mogamad Amien Crombie wrote:
Hi
I have 3 records like this:
record(ai, "$(dev):calcoffset") {
field(INP, "$(dev):rawval")
field(FLNK, "$(dev):offset PP")
field(OUT, "$(dev):offset")
field(VAL, "0")
All I want to do is to get a value from my Asyn INP (input) called
$(dev):rawval and assign the value to $(dev):offset.
Also I use $(dev):zeroOffset to set this to 0.
But somehow when I do a PUT to $(dev):calcoffset, my #(dev):offset is
not set to this INP value.
What I'm I doing wrong
Thanks
Amien Crombie
Cape Town
iThemba-LABS
- Setting RECORD value to another RECORD Mogamad Amien Crombie
RE: Setting RECORD value to another RECORD Mark Rivers
Re: Request for CSS PV Table new feature Kasemir, Kay
<2015>
Knauer Drivers kathryn.baker
<2015>
