1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Alarm handling
To: <[email protected]>
Date: Thu, 10 Dec 2015 15:29:07 -0600
On 12/10/2015 02:54 PM, Henrique Almeida wrote:
>  Hello, what's the proper way to process a record if and only if another
> record raises an alarm ?
As Stephanie said TMTOWTDI.
My approach would be to have the second record's SDIS link point to the
SEVR field of the first record and also set its DISV field to 0. If you
give that SDIS link the CP flag the second record will try to process
whenever the alarm severity of the first record changes, but processing
will be disabled when that severity is 0 (NO_ALARM). You don't have to
use that CP trick though, if you want the second record to process every
time the first one does you could forward link from the first to the second.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Alarm handling Henrique Almeida
Prev: RE: Alarm handling Arnold, Ned D.
Next: RE: Request for CSS PV Table new feature Patard Charles-Henri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
