1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Alarm handling
Date: Thu, 10 Dec 2015 21:17:40 +0000
* Set all the records you want to process when the alarm occurs to *.SCAN=Event; EVNT=<reserved_event_1>
* Use a calcout record to monitor the records you want to respond to and the conditions on which to take action ...
  <importantPV1.SEVR>
  <importantPV2.SEVR>
* set the "Out Event" field of the calcout record (OEVT) to <reserved_event_1>
Numerous records will scan when your conditions are met.
  Ned
From: [email protected] [[email protected]] on behalf of Henrique Almeida [[email protected]]
Sent: Thursday, December 10, 2015 02:54 PM
To: [email protected] Talk
Subject: Alarm handling
 Hello, what's the proper way to process a record if and only if another record raises an alarm ?
Alarm handling Henrique Almeida
Prev: Re: Alarm handling Kasemir, Kay
Next: Re: Alarm handling Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
