1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Alarm handling
To: Henrique Almeida <[email protected]>
Date: Thu, 10 Dec 2015 21:17:16 +0000
> On Dec 10, 2015, at 3:54 PM, Henrique Almeida <[email protected]> wrote:
>  Hello, what's the proper way to process a record if and only if another record raises an alarm ?
Not sure about ‘proper’, but now way that allows you full control would be a calcout record.
INPA points to the *.SEVR field of the record you want to check.
OUT points to the record that you want to process.
In CALC you can check for A>0 or A== some specific severity level.
In the OOPT you can then use "Transition to Non-zero” to process when you have the desired alarm.
-Kay
Alarm handling Henrique Almeida
Prev: RE: Alarm handling Allison, Stephanie
Next: RE: Alarm handling Arnold, Ned D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
