.I missed that. Yes, you need a separate address structure and length to hold the sender address.
The problem is that when recvfrom() is called in readIt() and flushIt(), the IP address and port of the remote sender will replace the values in tty->farAddr.oa.sa. This means that the next time octetWrite() is called, it will call sendto() using the address of the last responder, not the address that was originally specified when creating the port. I don’t think this is the correct behavior. The solution is to use a local osiSockAddr variable to receive the sender’s address information in readIt() and flushIt(), not tty->farAddr.oa.sa.
- RE: Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
- Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
- Re: Proposed change to asyn drvAsynIPPort for UDP sockets Henrique Almeida
- Re: Proposed change to asyn drvAsynIPPort for UDP sockets Torsten bögershaus
- Re: Proposed change to asyn drvAsynIPPort for UDP sockets Eric Norum
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
