Good Afternoon,
I found the following information on the EPICS Hardware Support: by Contact page.
Ian Gillingham <ian.gillingham_at_diamond.ac.uk>
Bus
Manufacturer
Module
Description
Link
RS-232 (Asyn)
MKS Instruments
mks9xx
MKS 901, 901P, 925, 971B, 972B, 974B vacuum gauge support
RS-232 (Streams)
ENZ / FMB
LoCuM-4
4 Channel Low Current Monitor. Input > 10 pA < 1 mA; Output +/-10V
RS-232 (Streams)
MKS Instruments
MKS937B
vacuum gauge controller
RS-232 (Streams)
MKS Instruments
PR4000B
Baratron gauge controller
RS-232 (Streams)
Thurlby Thandar Instruments (TTi)
EX355P
Programmable Bench Power Supply
We are interested in Stream Device support for both the MKS 937B Vacuum Gauge Controller and the MKS PR4000B Digital Power Supply and Readout Controller (http://www.mksinst.com/product/product.aspx?ProductID=831).
I have not had any luck reaching Ian Gillingham via email and therefore am wondering if someone who monitors tech talk may be able to provide me with access to the stream device support that has been developed for these two devices.
Also, we have run into a problem connecting the MKS 937B to an IOC (Moxa DA-662). It seems that this connection may be causing a ground loop. When we connect to the IOC the controller no longer displays valid readings (reading goes to
1x10-11)? Has anyone run into this before? We ran into the same problem when connecting the analog outputs from the MKS 937B to Modicon PLC inputs. We were able to resolve the problem by not tying the analog signals to ground at the PLC input terminal blocks.
Any feedback anyone can provide on their experience, particularly any issues they have run into with either of these devices, is greatly appreciated.
Thanks in advance.
Tonia Batten, P.Eng
Control System Analyst
Canadian Light Source
44 Innovation Blvd.
Saskatoon, SK S7N 2V3
Tel: 306-657-3865
Email: [email protected]
- RE: Stream Device Support for MKS 937B and MKS PR4000B ian.gillingham
RE: Redundancy support Bruins, Stefan
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
