1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Newport 8742 Picomotor Controller Driver
To: Adam Bark <[email protected]>
Cc: [email protected]
Date: Fri, 4 Dec 2015 16:41:01 -0500
On Wed, Oct 14, 2015 at 11:57:21AM +0100, Adam Bark wrote:
> >On 13/10/15 16:15, Adam Bark wrote:
> >>It seems this device has been discussed before but I can't find
> >>a driver, does anyone have one that they are willing to share?
A preliminary attempt at the 8742 driver is in the 'newfocus874x' branch
here:
https://github.com/waynelewis/motor
It's in the NewFocusSrc directory, and gets incorporated into the
NewFocus library.
I've tested it on an 8742 successfully, but not extensively. Once I've
done some more testing, I'll send a pull request to get it into the
motor EPICS module.
Note that the 874x series uses a different command set to the 875x
series. The old 875x series support remains unchanged.
Wayne
Newport 8742 Picomotor Controller Driver Adam Bark
Re: Newport 8742 Picomotor Controller Driver Adam Bark
Prev: EPICS 2016 Spring Meeting at ESS, Lund, Sweden Timo Korhonen
Next: Installing EPICS base and all related extensions Epics Damavand
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Newport 8742 Picomotor Controller Driver Adam Bark
Next: RE: Tech-talk Digest, Vol 9, Issue 320 Gofron, Kazimierz
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
