1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: ai RVAL via asyn + modbus: getting unsigned integer
Date: Thu, 3 Dec 2015 10:16:48 -0800 (PST)
On Thu, 3 Dec 2015, Mark Rivers wrote:
Hi Jon,
http://cars9.uchicago.edu/software/epics/modbusDoc.html
Supported Modbus data types
modbusDataType value    drvUser field   Description
0       UINT16  Unsigned 16-bit binary integers
4       INT16   16-bit signed (2's complement) integers. This data type extends the sign bit when converting to epicsInt32.
So modbusDataType=0 is UINT16, unsigned 16-bit integer.  That explains your problem, you should be using modbusDataType=4 (INT16) and your command line should be:
drvModbusAsynConfigure("CollimCouch", "AcromagCollimCouch",0,4,0,9,4,100,"AcromagXT1221")
That must be it. The referenced documentation is for Modbus release 2-7 and we are still running 2-2, which only supports data type codes 0 - 3. When we try code 4 in 2-2, RVAL is always 0. The 2-2 doc says:
Type 0 is used for binary numbers in twos-complement format. The data can either be signed or unsigned.
But, as we found, it isn't very helpful for signed integers.
Thanks for clearing this up.
Jon Jacky
RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
Prev: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Next: RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
