One solution would be to add the following commands to your startup script before iocInit:
asynOctetConnect("myDevice", "myPort", 0)
asynOctetWrite("myDevice", "*RST")
where "myPort" is the name of the asynIP or asynSerial port, and "myDevice" is an arbitrary name you chose.
That way you will reset the device before the @init sections are run, which happens as part of iocInit.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Christian Pauly
Sent: Wednesday, December 02, 2015 12:52 PM
To: EPICS Tech Talk
Subject: Streamdevice initialization sequence
Hi
I have a question regarding Streamdevice and the initialization of the
hardware on ioc startup.
I would liko to control an Agilent 33250A Pulse generator using stream
device.
In order to put the device in a well defined ground state on startup of
the IOC, i would like to send a RESET command ("*RST") first.
Afterwards i would like to put the device in a well-defined initial
configuration (which might be different then the reset state) by using
the @init directive in different protocol functions (as described in the
streamdevice docu).
The best would be, to have a separate protocoll function with @init
section, which is only used for initial reset+configuration, and which
is for sure processed before all others.
However, after some trying and reading the manual, i understand that the
individual @init sections from different protocol functions are
processed in a more or less random, non-defined order.
How can i make sure, that a "*RST" command is executed first, before
later the individual protocol routines @init sections are used to read
the device status into the control records
(here i dont care any more about the sequence)?
I dont want to shift all initialization into the db record definition
using a initialization record ("PINI 1"), since then the individual
@init sections, used to fill the records with the actual device status
at startup, would be processed before the *RST command, and the records
would not reflect the real device status at startup.
Is there any standard concept for this problem ?
Thanks for any advice,
Christian
- Streamdevice initialization sequence Christian Pauly
problem building msi with base-3.15.3 Jemian, Pete R.
<2015>
<2015>
