1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: migration from old EPICS Base
To: <[email protected]>
Date: Wed, 2 Dec 2015 11:59:26 -0600
Hi Jiro,
On 12/02/2015 10:52 AM, Jiro Fujita wrote:
> Yes, I have looked at the guideline (although I admit it has been a
> while since the last time when I looked at it).  We are still in early
> stage in the process on this migration, if we ever make the move.  The
> plan is that we will use MVME3100 instead of old MVME164/167, if we ever
> make the transition (I have been able to boot RTEMS on MVME3100).
Make sure that you test every type of VME slave board that you're going
to be using with a real MVME3100 CPU before you go ahead and buy them
all, we have found that some of the older VME boards designed in the age
of 68K-based CPUs don't work with the Universe and/or Tempe VME
interface chips used on the newer CPUs. In some cases we've been able to
fix the slave or adjust the driver software, but you might find that you
need to replace some of your older board types.
The MVME3100 is based on a different PowerPC CPU family than the other
PowerPC MVME boards which has a deeper and more aggressively optimized
write pipeline, so drivers that work fine on an MVME2100, 5100 or 6100
board may need changing slightly to work with the 3100. This usually
just involves adding a dummy read of the last register written to at the
end of the interrupt service routine (the read operation causes the CPU
to wait until the write pipeline has been flushed).
HTH,
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
migration from old EPICS Base Jiro Fujita
Re: migration from old EPICS Base Jiro Fujita
Prev: Re: migration from old EPICS Base Wesley Moore
Next: Streamdevice initialization sequence Christian Pauly
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: migration from old EPICS Base Jiro Fujita
Next: Re: migration from old EPICS Base Jiro Fujita
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
