Jiro,
I see we have 3.14 drivers for the 3122 and the 4116 (for vxworks). I’ll talk to someone here that’s worked with linux on vme and get back to you with some details and contact info.
Wesley
> On Dec 2, 2015, at 12:00 PM, Jiro Fujita <[email protected]> wrote:
> Wesley,
> Ah, that would be helpful to know if you are indeed running VME 3122 under 3.14. Particularly, if you have any tricks/code modifications, etc.
> I have no experience in Linux RT, but am willing to give it a try. I have briefly looked into it, but it seemed more work than I wanted to spend on it. Perhaps I should revisit the idea.
> On Dec 2, 2015, at 10:36 AM, Wesley Moore wrote:
>> Jiro,
>> I’m pretty sure I’ve run the VME 3122 under 3.14. I can confirm if needed. I haven’t used RTEMS on VME, but you may want to investigate linux rt. I believe in all but worst case scenarios, performance isn’t an issue. Seems to be a lot easier to support.
>> Wesley
>>> On Dec 2, 2015, at 11:20 AM, Jiro Fujita <[email protected]> wrote:
>>> So, here is a question to people who has been in the control business for a while.
>>> At STAR experiment at Brookhaven National Lab, we still have some IOCs running EPICS Base 3.12 (as well as 3.13 and 3.14). Since prior to EPICS 3.14, we could only use EPICS with VME boards, they are running on VME CPUs. All of them are basically frozen systems. We do boot them from a Linux host, but we have not made any changes to them for several years.
>>> As we try to deal with the aging older hardware, I have found that we are still using the following VME boards in those old EPICS Base 3.12 based IOCs:
>>> VMIVME 1111 64-bit High-Voltage Digital Input Board
>>> VMIVME 2232 32-Channel Relay Output Board
>>> VMIVME 3122 16-bit Analog-To-Digital Converter Board
>>> VMIVME 4116 8-Channel 16-bit Analog Output Board
>>> LeCroy 1176 TDC Time-to-Digital Converter Board
>>> Acromag AVME 948X Digital I/O card
>>> I realize many of VMIVME boards are listed in EPICS Hardware Support section, but many of them has no contact person listed (nor the code), not clear if it is supported in EPICS Base 3.14.
>>> Does anybody by any chance still use them with EPICS Base 3.14 or even 3.15? If you do, please let me know. Note that if we are to move VME IOCs to EPICS Base 3.14, it is very likely that we will use RTEMS instead of VxWorks (mostly cost issues). So any experiences of migrating from VxWorks to RTEMS is also welcome.
>>> If anybody have replaced them to something newer that are better supported in EPICS Base 3.14/3.15, I am also interested to hear what you replaced them with.
>>> My thought is that anything that's currently running with EPICS Base 3.12 stable, we should leave them alone in general, given the lack of man power and budget to move them to newer systems. However, my boss thinks otherwise, so I was given a task of looking into the possibilities and options.
- migration from old EPICS Base Jiro Fujita
- Re: migration from old EPICS Base Jiro Fujita
Re: migration from old EPICS Base Andrew Johnson
<2015>
Re: migration from old EPICS Base Hartman, Steven M.
<2015>
