1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: migration from old EPICS Base
To: Eric Norum <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 2 Dec 2015 10:52:20 -0600
Hi Eric,
Yes, I have looked at the guideline (although I admit it has been a while since the last time when I looked at it).  We are still in early stage in the process on this migration, if we ever make the move.  The plan is that we will use MVME3100 instead of old MVME164/167, if we ever make the transition (I have been able to boot RTEMS on MVME3100).
On Dec 2, 2015, at 10:35 AM, Eric Norum wrote:
Have you had a look at the conversion guidelines?  https://wiki-ext.aps.anl.gov/epics/index.php/How_to_make_your_EPICS_driver_operating_system_independent
Are your CPU modules supported by RTEMS?
On Dec 2, 2015, at 8:20 AM, Jiro Fujita <[email protected]> wrote:
Does anybody by any chance still use them with EPICS Base 3.14 or even 3.15?  If you do, please let me know.  Note that if we are to move VME IOCs to EPICS Base 3.14, it is very likely that we will use RTEMS instead of VxWorks (mostly cost issues).  So any experiences of migrating from VxWorks to RTEMS is also welcome.
Eric Norum
[email protected]
Re: migration from old EPICS Base Andrew Johnson
migration from old EPICS Base Jiro Fujita
Prev: migration from old EPICS Base Jiro Fujita
Next: Re: Agilent DSO-X 2014A (AKA Keysight Infinivision X-series oscilloscopes) Lionberger, Carl A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: migration from old EPICS Base Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
