hi, Shankar, Murali: Here is the grep result in logs: ----------------------------------------------------------- arch.log:10495 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service
arch.log:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality. arch.log:8507 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service arch.log:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality. arch.log:8446 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service arch.log:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality. arch.log:8573 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service arch.log:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality. arch.log:9066 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service arch.log:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality. arch.log.2015-11-30:7358 [localhost-startStop-1] FATAL org.epics.archiverappliance.config.ArchServletContextListener - Exception initializing config service arch.log.2015-11-30:org.epics.archiverappliance.config.exception.ConfigException: The hostname from appliances.xml is appsvr0.ssrf.ac.cn and from a call to InetAddress.getLocalHost().getCanonicalHostName() (typially FQDN) is 159.226.222.248. These are not identical. They are probably equivalent but to prevent multiple appliances binding to the same identity we enforce this equality. catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [BPLServlet] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException catalina.err:SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception catalina.err:java.lang.NullPointerException ----------------------------------------------------------- in appliances.xml, If I just deploy archiver in one machine without hostname, how to modify it? ----------------------------------------------- <appliances>
<appliance> <identity>appliance0</identity> <cluster_inetport>appsvr0.ssrf.ac.cn:16670</cluster_inetport> <mgmt_url>http://appsvr0.ssrf.ac.cn:17665/mgmt/bpl</mgmt_url> <engine_url>http://appsvr0.ssrf.ac.cn:17666/engine/bpl</engine_url> <etl_url>http://appsvr0.ssrf.ac.cn:17667/etl/bpl</etl_url> <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url> <data_retrieval_url>http://appsvr0.ssrf.ac.cn:17668/retrieval</data_retrieval_url> </appliance> </appliances> ----------------------------------------------- I checked the messages in tech-talk, it says caj doesn't support 64bit well, I just download caj-1.1.8.jar.
in apache-tomcat-7.0.65/logs, there is no logs newly created. If I visit 192.168.1.151:17665, the tomcat can be displayed correctly. thanks a lot for your help. Best wishes Geyang 2015-12-01 ##############on 2015-12-01, [email protected] wrote:###############
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
