hi, I install it on a centos6.5 64bit machine, with single_machine_install.sh, there is no error. but when I try to visit the URL like
http://192.168.1.151:17665/mgmt/ui/index.html, it shows the error like following: HTTP Status 500 -type Exception report message description The server encountered an internal error that prevented it from fulfilling this request. exception java.lang.NullPointerException org.epics.archiverappliance.mgmt.MgmtUIFilter.doFilter(MgmtUIFilter.java:33) note The full stack trace of the root cause is available in the Apache Tomcat/7.0.65 logs. Apache Tomcat/7.0.65If I use quick start, the web site is ok. also I have installed mysql,tomcat, etc.. what's the problem? Thanks you very much for help. Followings is the message from tomcat/mgmt/logs/catalina.err file: Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version: Apache Tomcat/7.0.65 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Server built: Oct 9 2015 08:36:58 UTC Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Server number: 7.0.65.0 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: OS Name: Linux Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: OS Version: 2.6.32-431.el6.x86_64 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Architecture: amd64 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Java Home: /usr/java/jdk1.8.0_65/jre Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: JVM Version: 1.8.0_65-b17 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: JVM Vendor: Oracle Corporation Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: CATALINA_BASE: /root/tomcat/mgmt Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: CATALINA_HOME: /root/tomcat/apache-tomcat-7.0.65 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -XX:MaxPermSize=128M Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -XX:+UseG1GC Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Xmx4G Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Xms4G Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -ea Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcatalina.base=/root/tomcat/mgmt Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcatalina.home=/root/tomcat/apache-tomcat-7.0.65 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcommons.daemon.process.id=3164 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcommons.daemon.process.parent=3163 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcommons.daemon.version=1.0.15-dev Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: abort Nov 30, 2015 2:42:51 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /root/tomcat/mgmt/webapps/engine/WEB-INF/lib/native/linux-x86_64:/usr/local/lib:/usr/lib:/usr/X11R6/lib:/usr/local/epics/r3.14.11/base/lib/linux-x86:/usr/local/epics/r3.14.11/extensions/lib/linux-x86:/usr/local/epics/r3.14.11/extensions/src/epicsqt/framework/designer:/usr/java/jdk1.8.0_65/jre/lib/amd64/server:/usr/java/jdk1.8.0_65/jre/lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib Nov 30, 2015 2:42:51 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-17665"] Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 758 ms Nov 30, 2015 2:42:51 PM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina Nov 30, 2015 2:42:51 PM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.65 Nov 30, 2015 2:42:51 PM org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive /root/tomcat/mgmt/webapps/mgmt.war Nov 30, 2015 2:42:54 PM org.apache.catalina.startup.TldConfig execute INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. Nov 30, 2015 2:42:54 PM org.apache.tomcat.jdbc.pool.ConnectionPool checkPoolConfiguration WARNING: maxIdle is larger than maxActive, setting maxIdle to: 10 Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.HostConfig deployWAR INFO: Deployment of web application archive /root/tomcat/mgmt/webapps/mgmt.war has finished in 11,474 ms Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /root/tomcat/mgmt/webapps/docs Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.TldConfig execute INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. Nov 30, 2015 2:43:03 PM org.apache.tomcat.jdbc.pool.ConnectionPool checkPoolConfiguration WARNING: maxIdle is larger than maxActive, setting maxIdle to: 10 Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deployment of web application directory /root/tomcat/mgmt/webapps/docs has finished in 306 ms Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /root/tomcat/mgmt/webapps/host-manager Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.TldConfig execute INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. Nov 30, 2015 2:43:03 PM org.apache.tomcat.jdbc.pool.ConnectionPool checkPoolConfiguration WARNING: maxIdle is larger than maxActive, setting maxIdle to: 10 Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deployment of web application directory /root/tomcat/mgmt/webapps/host-manager has finished in 250 ms Nov 30, 2015 2:43:03 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /root/tomcat/mgmt/webapps/examples Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.TldConfig execute INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. Nov 30, 2015 2:43:04 PM org.apache.tomcat.jdbc.pool.ConnectionPool checkPoolConfiguration WARNING: maxIdle is larger than maxActive, setting maxIdle to: 10 Nov 30, 2015 2:43:04 PM org.apache.catalina.core.ApplicationContext log INFO: ContextListener: contextInitialized() Nov 30, 2015 2:43:04 PM org.apache.catalina.core.ApplicationContext log INFO: SessionListener: contextInitialized() Nov 30, 2015 2:43:04 PM org.apache.catalina.core.ApplicationContext log INFO: ContextListener: attributeAdded('org.apache.jasper.compiler.TldLocationsCache', 'org.apache.jasper.compiler.TldLocationsCache@722d7a92') Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deployment of web application directory /root/tomcat/mgmt/webapps/examples has finished in 640 ms Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /root/tomcat/mgmt/webapps/ROOT Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.TldConfig execute INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. Nov 30, 2015 2:43:04 PM org.apache.tomcat.jdbc.pool.ConnectionPool checkPoolConfiguration WARNING: maxIdle is larger than maxActive, setting maxIdle to: 10 Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deployment of web application directory /root/tomcat/mgmt/webapps/ROOT has finished in 232 ms Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory /root/tomcat/mgmt/webapps/manager Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.TldConfig execute INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time. Nov 30, 2015 2:43:04 PM org.apache.tomcat.jdbc.pool.ConnectionPool checkPoolConfiguration WARNING: maxIdle is larger than maxActive, setting maxIdle to: 10 Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deployment of web application directory /root/tomcat/mgmt/webapps/manager has finished in 81 ms Nov 30, 2015 2:43:04 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-bio-17665"] Nov 30, 2015 2:43:04 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 13063 ms Nov 30, 2015 2:43:44 PM org.apache.catalina.core.StandardWrapperValve invoke SEVERE: Servlet.service() for servlet [StaticContent] in context with path [/mgmt] threw exception java.lang.NullPointerException at org.epics.archiverappliance.mgmt.MgmtUIFilter.doFilter(MgmtUIFilter.java:33) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745) Best wishes Geyang 2015-11-30
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
