1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Missaligned protocol rejected when using caPutLog
To: [email protected]
Date: Tue, 24 Nov 2015 08:44:02 -0500
The CA server is complaining because caPutLog speaks a different protocol and requires a different server.  caPutLogInit should never be given port 5064.
You should investigate the iocLogServer executable which is built as part of epics base which speaks the protocol used by caputlog.  By default this listens on port 7004.  This is designed to act as a central log server for many IOCs.
I also have https://github.com/mdavidsaver/ioclogserv2 with some additional features including better log file rotation behavior.
On 11/24/2015 04:49 AM, Qiao Yusi wrote:
> Hi, everyone:
> I’m a newbie at EPICS. I have some trouble running caPutLog on RedHat Linux. When using caput to change a pv value, here came:
> epics> CAS: request from 192.168.206.74:32975 => "CAS: Missaligned protocol rejected"
> CAS: Request from 192.168.206.74:32975 => cmmd=12852 cid=0x35203131 type=28534 count=11569 postsize=11598
> CAS: Request from 192.168.206.74:32975 =>  available=0x3a34323a         N=0 paddr=(nil)
> CAS: forcing disconnect from 192.168.206.74:32975
> So my logfile can only log the error.
> The IOC is running on epics-base 3.14.12.1, and the caPutLog version is 3.4.
> My server and client are on the same host, and here are some related environment variables, the host IP is 192.168.206.74:
> export EPICS_CA_AUTO_ADDR_LIST=NO
> export EPICS_CA_ADDR_LIST=192.168.206.74
> export EPICS_IOC_LOG_INET=192.168.206.74
> export EPICS_IOC_LOG_PORT=7004
> export EPICS_IOC_LOG_FILE_NAME=/home/qys/save/logfile
> I can’t figure out what is wrong. Hope someone can help me. Thanks!
> (More details please see the attachment.)
Missaligned protocol rejected when using caPutLog Qiao Yusi
Prev: Re: Successfully locked memory using mlockAll Henrique Almeida
Next: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Missaligned protocol rejected when using caPutLog Qiao Yusi
Next: Re: caPutLog problem solved Qiao Yusi
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
