Hello, but these messages may appear to non root users, and are not really related to being root or not, but to the real time operations in libCom. For example: [henrique.almeida@SOL1-HOST1 linux-x86]$ cp caget /tmp/ [henrique.almeida@SOL1-HOST1 linux-x86]$ cd /tmp/ [henrique.almeida@SOL1-HOST1 tmp]$ sudo setcap 'cap_sys_nice+ep cap_ipc_lock+ep' ./caget [henrique.almeida@SOL1-HOST1 tmp]$ ./caget LNLS:ANEL:corrente Successfully locked memory using mlockAll LNLS:ANEL:corrente 227.682 In the example above, standard non-root user saw the debug message even though he's not root, only because I activated real time support. This looks like a design bug to me, because a helper library is writing on the standard error on behalf of the application when it was not asked for doing it. Can this feature be disabled ? 2015-11-23 19:44 GMT-02:00 Andrew Johnson <[email protected]>: Hi,
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
