1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Successfully locked memory using mlockAll
To: <[email protected]>
Date: Mon, 23 Nov 2015 15:44:23 -0600
On 11/23/2015 01:20 PM, Henrique Dante de Almeida wrote:
>  Hello, I'm testing EPICS base v 3.15 on a fresh Red Hat 6.6
> installation and after compiling, executing caget always returns
> the message "Successfully locked memory using mlockAll":
> [root@SOL1-HOST1 linux-x86]# ./caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente             161.585
> [root@SOL1-HOST1 linux-x86]# cd
> [root@SOL1-HOST1 ~]# caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente             161.553
> (etc.)
> Can the message be removed ? Here is what seems to be the relevant
> commit:
> https://code.launchpad.net/~mshankar/epics-base/memlock_linux/+merge/232466
Those messages will be printed to stderr if you run caget (or any other
program linked with our libCom library) as root. Using the root account
to run programs that don't need such privilege is a bad idea from a
computer security perspective though. Some sites do need to run certain
IOCs with root privilege to enable the real-time scheduler (which then
makes it desirable to lock the IOC code into physical RAM) or to access
certain I/O hardware from user-space, but in most cases we'd recommend
that you use a non-root account for programs like caget/caput/camonitor.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Successfully locked memory using mlockAll Henrique Almeida
Successfully locked memory using mlockAll Henrique Dante de Almeida
Prev: Re: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Pete Jemian
Next: Missaligned protocol rejected when using caPutLog Qiao Yusi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Successfully locked memory using mlockAll Henrique Dante de Almeida
Next: Re: Successfully locked memory using mlockAll Henrique Almeida
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
