Subject: |
g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh |
Heinz Junkes <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Thu, 19 Nov 2015 15:00:43 +0100 |
Hi all,
I am still fighting with glib running within procserv (or remote via ssh).
The aravislib used in areadetector to connect to GigE (Genicam) cameras uses glib.
Running the stuff locally works well. Running it remotely it fails.
Testfile:
h1@earth:~/ARAVIS/aravis/tests$ more loadhttptest.c
#include <glib.h>
#include <gio/gio.h>
#include <stdlib.h>
#include <stdio.h>
#include <arv.h>
int
main (int argc, char **argv)
GFile *file;
GFileInputStream *stream;
const char *filename;
char *genicam = NULL;
char **tokens;
gsize len = 0;
GError *err = NULL;
if (argc != 2) {
printf ("Usage: load-http-test <URL>\n");
return EXIT_FAILURE;
filename = argv[1];
tokens = g_regex_split (arv_gv_device_get_url_regex (), filename, 0);
if (tokens[0] != NULL && tokens[1] != NULL) {
if (g_ascii_strcasecmp (tokens[1], "http:") == 0) {
file = g_file_new_for_uri (filename);
stream = g_file_read (file, NULL, &err);
if (err != NULL) {
g_error("Could not open %s for reading: %s\n", filename, err->message);
g_error_free(err);
return 1;
if(stream) {
GDataInputStream *data_stream;
data_stream = g_data_input_stream_new (G_INPUT_STREAM (stream));
genicam = g_data_input_stream_read_upto (data_stream, "", 0, &len, NULL, NULL);
g_object_unref (data_stream);
g_object_unref (stream);
g_object_unref (file);
g_strfreev (tokens);
printf ("size = %lu\n", len);
printf ("%s\n", genicam != NULL ? genicam : "NULL");
g_free (genicam);
return EXIT_SUCCESS;
Running it locally it shows:
h1@earth:~/ARAVIS/aravis/tests$ ./load-http-test http://141.14.128.47/dias_gige_desc.xml
size = 64451
<?xml version="1.0" encoding="utf-8"?>
<RegisterDescription
ModelName="Pyroview"
VendorName="DIAS"
StandardNameSpace="None"
SchemaMajorVersion="1"
SchemaMinorVersion="0"
SchemaSubMinorVersion="1"
MajorVersion="1"
MinorVersion=“ …
<IntSwissKnife Name="NOT_TLParamsLocked">
<ToolTip>Negation of the TLParamsLocked value</ToolTip>
<Visibility>Invisible</Visibility>
<pVariable Name="TLPL">TLParamsLocked</pVariable>
<Formula>(TLPL = 0) ? 1 : 0</Formula>
</IntSwissKnife>
</RegisterDescription>
Running it remote via ssh it shows :
** (process:11455): ERROR **: Could not open http://141.14.128.47/dias_gige_desc.xml for reading: Operation not supported
Trace/breakpoint trap (core dumped)
I assume problems with dbus/session/stream stuff. About one year ago I could overcome the problem by adding the
following to the st.cmd used by procserv :
#!/bin/bash
PID_FILE=/tmp/dbus_pid
if [ -a $PID_FILE ]
then
# echo "$PID_FILE exists ..."
PID=`cat $PID_FILE`
# echo "kill_pid $PID"
kill -9 $PID
fi
if test -z "$DBUS_SESSION_BUS_ADDRESS" ; then
## if not found, launch a new one
eval `dbus-launch --sh-syntax --exit-with-session`
echo "D-Bus per-session daemon address is: $DBUS_SESSION_BUS_ADDRESS"
echo "$DBUS_SESSION_BUS_PID" >$PID_FILE
fi
#date
#sleep 1
#/usr/local/bin/arv-tool-0.4 -n 'DIAS Infrared GmbH-C1076026' genicam >/tmp/dias_genicam.out
#sleep 1
#date
cd /srv/ioc/sys/iocBoot/iocdias
./st.cmd
#kill -9 $DBUS_SESSION_BUS_PID
But this doesn’t help anymore.
Any Ideas?
Thx Heinz
smime.p7s
Description: S/MIME cryptographic signature
- [Solved] g_file_read (used in aravislib, areadetector) fails when running on a remote machine via ssh Heinz Junkes
Control Engineering positions at FRIB bob dalesio
<2015>
<2015>
