1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS migration and problem with linking container widget
To: Maurizio Montis <[email protected]>
Date: Fri, 13 Nov 2015 19:35:38 +0000
Hi:
There have been changes regarding the specific resize options:
Should the container resize to match its content,
or should the content resize to match the container,
or should nothing resize and there are scrollbars?
I’ve seen older displays that don’t work properly without updating those (new) options.
-Kay
> On Nov 13, 2015, at 11:15 AM, Maurizio Montis <[email protected]> wrote:
> Hi to Everyone,
> i have a question related to CSS control panels and widget: we developed
> a human-machine interface in CSS 3.2.16 (basic package, 64bit) for our
> project and it has been in production for about a year.
> Recently we are trying to move to CSS 4.1.0 (always basic package,
> 64bit) but we have some problem using the same OPI files: in particular
> linking containers don't work correctly, showing us a blank window
> instead of the OPI file desired.
> We also tried the nightly version (CSS 4.2.0 64bit): in this case the
> linking container widget is correctly initialized, but the OPI files it
> has to load don't follow the requirement defined through a dedicated
> rule.
> Is there some change related to this widget or related to some
> particular (new) configuration?
> Thank you a lot to everyone for any answer.
> Cheers
> - Maurizio
> ~~ Maurizio Montis - Control System Engineer ~~
>   mobile: +39 3408428089
>   mail: [email protected]
>   skype: maurizio_montis
> Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
>   V.le dell'Universita', 2
>   35020 LEGNARO (PD) - ITALY
Re: CSS migration and problem with linking container widget Maurizio Montis
Prev: CSS migration and problem with linking container widget Maurizio Montis
Next: Alternatives to softGlue? (re-configurable TTL I/O line logic controllable from EPICS) Andrew Gomella
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: CSS migration and problem with linking container widget Maurizio Montis
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
