After I type CL, the message is : 'CL' is not recognized as an internal or external command,
operable program or batch file.
There are no .obj files in /src/libCom/O.win32-x86, only .c and .d
Alex.
Sent: Friday, November 6, 2015 12:30 PM
To: Klyachko, Alexander Vitalievich; Mark S. Engbretson; Andrew Johnson; 'Engbretson, Mark S.'
Cc: [email protected]
Subject: RE: Building Epics base 3.15.2 in Windows 7
What is the contents of base/src/libCom/O.win32-x86? Are there any .obj files there?
-----Original Message-----
From: Klyachko, Alexander Vitalievich [mailto:[email protected]]
Sent: Friday, November 06, 2015 11:03 AM
To: Mark Rivers; Mark S. Engbretson; Andrew Johnson; 'Engbretson, Mark S.'
Subject: Re: Building Epics base 3.15.2 in Windows 7
I'm doing pretty much the same to what Mark recommends, with one exception:
since my version of VS 2015 does not have vcvarsall.bat at all, I'm calling vsvars32.bat directly. Is there something wrong with that?
set EPICS_HOST_ARCH=win32-x86
set PATH=C:\Program Files (x86)\GnuWin32\bin;C:\Strawberry\Perl\bin;C:\base-3.15.2\bin\win32-x86;%PATH%
call "C:\Program files (x86)\Microsoft Visual Studio 14.0\Common7\tools\vsvars32.bat"
P.S. To answer the previous questions: installed on my computer is VS 2015 Professional, I checked the Windows registry. Also, make was downloaded from http://www.aps.anl.gov/epics/download/tools/make-4.1-win64.zip as recommended in one of previous threads; I assume it is 4.1
Thanks, Alex.
Sent: Friday, November 6, 2015 11:00 AM
To: 'Mark S. Engbretson'; 'Johnson, Andrew N.'; 'Engbretson, Mark S.'; Klyachko, Alexander Vitalievich
That's a good point.
I recently posted a message to tech-talk describing how I create batch files and desktop shortcuts to properly set up a Windows cmd shell to build the win32-x86 and windows-x64 architectures.
http://www.aps.anl.gov/epics/tech-talk/2015/msg01582.php
From: Mark S. Engbretson [mailto:[email protected]]
Sent: Friday, November 06, 2015 9:37 AM
To: 'Johnson, Andrew N.'; 'Engbretson, Mark S.'; Mark Rivers; 'Klyachko, Alexander Vitalievich'
I can duplicate that exact same message if the path to the correct
vcvarsall.bat is incorrect or never run. The actually path to the compiler
isn't know.
i.e. in startup\win32.bat
call "C:\Program files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat"
x86
After make crashes, does typing CL on the command line do anything?
From: Johnson, Andrew N. [mailto:[email protected]]
Sent: Thursday, November 05, 2015 6:30 PM
To: Engbretson, Mark S. <[email protected]>; Rivers, Mark L.
<[email protected]>; 'Klyachko, Alexander Vitalievich'
<[email protected]>
On 11/05/2015 05:40 PM, Mark S. Engbretson wrote:
> For whatever it is worth, I also use MSVS2010, but did just grab the
> most recent tar from March 2015, that source file does exists in that
> directory, but to me, the problem is at the line
> process_begin: CreateProcess(NULL
I think this is a general error message produced by GNUmake on Windows when
it experiences certain kinds of problems. The parentheses contain a copy of
the previous command line that was output by make:
> cl -EHsc -GR -nologo -D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE
> -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -MD
> -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I ../O.Common -I.
> -I../../../src/libCom/osi/compiler/msvc
> -I../../../src/libCom/osi/compiler/default -I.
> -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default
-I..
> -I../../..
> /src/libCom/as -I../../../src/libCom/bucketLib
> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
> -I../../../src/libCom/ dbmf -I../../../src/libCom/ellLib
> -I../../../src/libCom/env -I../../../src/libCom/error
> -I../../../src/libCom/fdmgr -I../../../src/libCom/flex
> -I../../../src/libCom/freeList -I../../../src/l ibCom/gpHash
> -I../../../src/libCom/iocsh -I../../../src/libCom/log
> -I../../../src/libCom/macLib -I../../../src/libCom/misc
> -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src
> /libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer
> -I../../../src/libCom/yacc -I../../../src/libCom/yacc
-I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../.
> ./../include/os/WIN32 -I../../../include -c
> ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
> process_begin: CreateProcess(NULL, cl -EHsc -GR -nologo -D__STDC__=0
> -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy-
> -W3
> -w44355 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -T P -I. -I../O.Common
> -I. -I../../../src/libCom/osi/compiler/msvc
-I..
> -I
> ../../../src/libCom/as -I../../../src/libCom/bucketLib
> -I../../../src
> /libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
> -I../../../src/libCom/error -I../../../src/libCom/fdmgr
> -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../
> ../src/libCom/gpHash -I../../../src/libCom/iocsh
> -I../../../src/libCom/log -I../../../src/libCom/macLib
> -I../../../src/libCom/misc -I../../../src/libCom/osi
> ./../src/libCom/ring -I../../../src/libCom/taskwd
> -I../../../src/libCom/timer -I../../../src/libCom/yacc
> -I../../../src/libCom/yacc -I../../../src/libCom/yajl
> -I../../../include/compiler/msv c -I../../../include/os/WIN32
> ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
> make (e=2): The system cannot find the file specified.
> make[3]: *** No rule to make target 'epicsTempFile.obj', needed by
> 'antelope.exe'. Stop.
Make was looking for the .obj output file that was supposed to have been
created by the cl compiler, but couldn't find it. There could be various
reasons for that, disk space might be one or possibly file permissions
although that seems a little unlikely given that this isn't the first file
it tried to compile. I don't really have any other ideas what could be
causing the issue at this point.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has always got there
first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- RE: Building Epics base 3.15.2 in Windows 7 Mark S. Engbretson
- Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
- RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
- Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
<2015>
<2015>
