Hi David,
One thing to consider is the performance you need from the SIS3820 board. My EPICS driver can use DMA to read the FIFO at about 40 MB/s, while using programmed I/O is limited
to about 4 MB/s. DMA uses some routines from Andrew Johnson’s VxWorks Board Support Package. I think there may be RTEMs wrappers to use that Andrew’s API for DMA. I don’t know if they will work on an Intel CPU.
On Behalf Of David Vine
Sent: Thursday, November 05, 2015 7:01 PM
To: [email protected]
Subject: Advice on VME processor cards and OS for EPICS
Hi all,
I am looking to setup a VME crate and processor to run EPICS and synApps to control a STXM and handle data acquisition. Specifically I anticipate using a Struck multichannel scaler card (SIS3820) for data acquisition and OMS MAXv card for
stepper motor control.
vxWorks is not an option due to price. Since I will be maintaining the OS myself and I am no expert I am looking for the simplest OS to set up and maintain and ideally with existing support for the abovementioned cards. I am comortable
building EPICS and synApps on linux but I have no experience setting up a VME.
From my research I found two options and I'm hoping to get some advice on which option might be best:
RTEMS. The RTEMS source builder seems straight forward to use but I'd appreciate if someone can recommend a processor, or advice on how to choose one?
RT linux. I don't really know if this would work but I could use an Intel processor from acromag (link below) and install linux and run EPICS on it. Is there a VME bus driver and would it support the cards I mentioned above?
- Advice on VME processor cards and OS for EPICS David Vine
Re: Advice on VME processor cards and OS for EPICS Andrew Johnson
Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
<2015>
10 synApps modules moved to GitHub today Pete Jemian
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
