Hi Peter,
On 10/30/2015 12:06 PM, Heesterman, Peter J wrote:
> I did just reproduce the textual anomaly, while using make –j4, see
> attached screen shot.
GNU Make from version 4 onwards has a way to control how the output
streams from parallel jobs get displayed. I think all you're seeing is
that several jobs are printing to stdout at the same time and their
output streams are getting mixed up (which is the default behaviour),
but you can control exactly when they get printed with the option -O (or
--output-sync) as described here:
https://www.gnu.org/software/make/manual/html_node/Parallel-Output.html#Parallel-Output
Using 'make -j4 -O' is probably the simplest solution.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
- RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
- Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
<2015>
<2015>
