Hello,
I am writing because while building an IOC for the PerkinElmer area detector module 2-3, I found that
msi on windows expects ':' as path separator. This behaviour does not allow to
specify paths for "include" that reside on a different windows drive.
Has anyone else encountered this problem while using msi on windows?
How have you solved them?
My proposal introduces a "-w" switch. The changes are pasted below (changes made against msi 1-5).
I also posted my version at http://controls.diamond.ac.uk/downloads/other/files/patched-msi.c
Ronaldo
--- /dls_sw/epics/R3.14.12.3/extensions/src/msi/msi.c 2013-01-18 20:25:57.045064658 +0000
+++ /home/rjq35657/msi/msi.c 2015-10-21 18:30:29.000000000 +0100
@@ -54,6 +54,7 @@
/*Exit status*/
static int exitStatus = 0;
+static int windowsPaths = 0;
int main(int argc,char **argv)
@@ -87,6 +88,8 @@
} else if(strncmp(argv[1],"-V",2)==0) {
macSuppressWarning(macPvt,0);
narg = 1; /* no argument for this option */
+ } else if(strncmp(argv[1],"-w",2)==0) {
+ windowsPaths = 1;
} else {
usageExit();
@@ -131,7 +134,7 @@
void usageExit(void)
- fprintf(stderr,"usage: msi -V -opath -Ipath ... -Msub ... -Ssubfile template\n");
+ fprintf(stderr,"usage: msi -w -V -opath -Ipath ... -Msub ... -Ssubfile template\n");
fprintf(stderr," Specifying path will replace the default '.'\n");
fprintf(stderr," stdin is used if template is not given\n");
exit(1);
@@ -293,16 +296,17 @@
const char *pdir;
int len;
int emptyName;
+ char pathSeparator = windowsPaths ? ';' : ':';
pdir = path;
/*an empty name at beginning, middle, or end means current directory*/
while(pdir && *pdir) {
- emptyName = ((*pdir == ':') ? 1 : 0);
+ emptyName = ((*pdir == pathSeparator) ? 1 : 0);
if(emptyName) ++pdir;
ppathNode = (pathNode *)calloc(1,sizeof(pathNode));
ellAdd(ppathList,&ppathNode->node);
if(!emptyName) {
- pcolon = strchr(pdir,':');
+ pcolon = strchr(pdir,pathSeparator);
len = (pcolon ? (pcolon - pdir) : strlen(pdir));
if(len>0) {
ppathNode->directory = (char *)calloc(len+1,sizeof(char));
- Re: msi for windows IOC build Andrew Johnson
RE: Subject: RE: To read single element from waveform record Mark Rivers
Using V4 pvCommonCPP module with external boost library alan.greer
<2015>
Re: Subject: RE: To read single element from waveform record Andrew Johnson
<2015>
